accessing rear plugs?
Old Oct 3, 2021 | 08:27 PM
spellman1989's Avatar
2002 CLK 320
Exclamation accessing rear plugs?
Ok so I'm changing my spark plugs but I noticed the rear plugs on either side are nearly impossible to access. Is the only way to access them with the 17mm mercedes tool? I used a 90 degree offset pliers on the others that I could access.TYIA
Old Oct 5, 2021 | 01:16 AM
TheUnknownMan's Avatar
2000 Clk320
I'm doing my spark plugs as well. But I'm also replacing valve gaskets. After removing the valve covers, there is plenty of room.
