Does anyone know how to reset the FSS
Old Sep 21, 2004 | 07:00 PM
TD430CLK's Avatar
2001 CLK 430
My car is almost 50K miles so I need to do the oil change on my own. But I don't know to reset the maintenance schedule. Does any know know?
Thanks a bunch.
TD430CLK
Old Sep 21, 2004 | 07:10 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Yes, there are people that know.
However:
1) what year is your car? It makes a difference
2) where are you located? The answer to #1 may change what you mean when you state the year of the car
3) the answer is probably in your owner's manual
-s-
Old Sep 21, 2004 | 08:02 PM
TD430CLK's Avatar
2001 CLK 430
I own a 2001 CLK 430 and I'm living in Maryland.
Thanks,
TD430CLK
Old Sep 21, 2004 | 09:17 PM
scorchie's Avatar
Thanks,
TD430CLK
The answer is definitely in your owner's manual!
-s-
Old Sep 21, 2004 | 09:33 PM
charliev68's Avatar
2000 CLK430
with the key on and the ignition on.
go to the fss screen where it says "service in xxxxxx miles"
push and hold the R button and the side of the cluster, it will ask if you want to reset, hit the R button again.
Old Sep 21, 2004 | 11:18 PM
smalldog's Avatar
clk
Will these steps work for a 2000 clk 320?
Old Sep 22, 2004 | 07:20 AM
TD430CLK's Avatar
2001 CLK 430
What do you mean by "the side of the cluster"? Do you mean the up and down button on top of the R button?
Old Sep 22, 2004 | 09:50 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
I think he meant to say hold the "R" button ON the side of the cluster...
Old Sep 30, 2004 | 12:59 PM
TD430CLK's Avatar
2001 CLK 430
Still need help, all the answers above doesn't work. Any other suggestions?
Thanks,
TD430CLK
Old Sep 30, 2004 | 03:10 PM
str8ridin's Avatar
05 E55
Try this:
Turn the electronic key in steering lock to position 2. To call up the trip odometer and main odometer, press button 3 or 4 on the multifunction steering wheel until the display appears.
Press button 5 or 6 until the FSS indicator appears.
Press button 'R' on the instrument cluster for approximately 2 seconds.
The multifunction display will show the question:
'DO YOU WANT TO RESET SERVICE INTERVAL? - CONFIRM BY PRESSING R'
Press button 'R' on the instrument cluster again, and hold until a signal sounds. The message 'SERVICE INTERVAL HAS BEEN RESET' appears in the multifunction display.
The new service indicator is displayed with the reset distance of 10,000 miles
Don’t let go the 0 button until you hear the bip, & you might need to have the driver’s door closed.
(Tried it again with driver side door closed!)
Old Oct 1, 2004 | 04:48 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
FSS Definition (while we're on the topic)
Since 1998, we've equipped all new Mercedes-Benz vehicles with the Flexible Service System (FSS). An electronic monitor checks the quantity and, on the advanced version in our new family of V6 and V8 vehicles, the condition of your engine oil. A "wrench light" on your dashboard lets you know when it's time for a regular maintenance service.
While each Mercedes-Benz is precision-crafted to exacting standards, not all drivers are alike. The Flexible Service System (FSS) accommodates the service requirements created by your individual driving style. By constantly monitoring your engine oil, the FSS may extend the service interval, which averages about 10,000 miles, without sacrificing the performance and protection you expect from your Mercedes-Benz.*
FSS evaluates engine temperature, oil level, vehicle speed, engine speed, distance driven and the time elapsed since your last service. It determines when your vehicle needs service and alerts you well in advance.
Each time you start your engine after you are approximately 2,500 miles or 30 days from requiring service, the dashboard readout displays a 10-second message telling you when your vehicle is due for service.
The advanced version of FSS also alerts you when your oil level is below minimum or above maximum. It even indicates how much oil you need to add. And if you add oil between service visits, the system automatically recognizes the change and lengthens the interval between service requirements.
From the MBUSA site.
Old Oct 5, 2004 | 11:43 PM
oldnews's Avatar
Maybe a stupid question on my part but; have you already changed the oil? If you try to reset the FSS before changing oil it won't do it. The engine has a viscosity/pollutant sensor and will only be reset with clean oil in the crankcase.
Old Jan 6, 2005 | 03:19 AM
myNAMESterry's Avatar
991.1 gt3, w204 c63 507
if this question still hasn't been answered.. i can help...
i just changed my oil today... my friend thought 9.5 quarts was a ridiculous amount. i have a '99 clk430 and to reset the FSS you have to do a few steps as indicated in page 93 of the owner's manual.
Turn electornic key in steerring lock position 2.
Within 4 seconds press button "0" twice.
Press and hold button "0", while turning electronic key in steering lock to position 2 again. The present status for days or distance is displayed once more. Continue to hold button "0".
After approx. 10 seconds a signal sounds, and the display shows 10,000 miles (Canada: 15,000KM) for approx. 10 seconds.
Release button "0"
if you do it right.. you should be able to see 10,000 miles.
Old Jan 11, 2005 | 11:29 PM
Co 55 AMG's Avatar
W208
This site is the best!
Old Jan 12, 2005 | 12:02 AM
its one of the best sites for benz discussions, yes
Old Jan 7, 2006 | 02:56 PM
chien tong's Avatar
hello small dog
CAN YOU TELL ME HOW TO RESET THE SERVICE B ON MY 2000 CLK320.
CAN I DO IT BY MYSELF, AND CAN YOU GIVE ME INFORMATION ABOUT THE FSS TOOLS SO I CAN BUY IT TO RESET IF I AN'T DO IT, THANK
Old Apr 6, 2006 | 02:33 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
OO, I just did this for my car (w203) and it worked! I had previously read directions saying that i needed to have my key in position 1, nope... Should be in position 2 like stated in this thread!
Great thread!
Old Jun 2, 2008 | 10:01 PM
Rocco Vespe's Avatar
2003 SL500
how about resetting th fss on a 1999 sl 500
I just changes oil - mobil one - can't seem to be able to reset fss even after carefully following instructions in owners manual three times. I get a to a small oil can and a clock, thats it. cant lose the wrench on start up.
Help,
Rocco
