How to remove instrument cluster?
Old Sep 21, 2004 | 08:12 PM
str8ridin's Avatar
05 E55
Aye, a stupid bulb went out behind my fuel gauge. Does anybody know how to replace it? I'm guessing pulling out the instrument cluster?
Old Sep 22, 2004 | 12:37 AM
midget fidger's Avatar
E550 Coupe
i saw some guy over in the C32 forum took out his whole cluster and changed it over to blue LEDs...might be able to get somethin from that but then again it might be completely diff from the CLK
Old Sep 22, 2004 | 04:59 PM
BklynBenz's Avatar
CL500
i saw steve take mine out when he did the comand retrofit and he took off a cover down under the steering wheel area (above your legs in the drivers side foot area) and then he stuck his arm up through their and pushed it out. if you try to pry it out from the front you chance wrecking it.
Old Sep 22, 2004 | 05:01 PM
str8ridin's Avatar
05 E55
Interesting. I looked under there and there was a hella lot of wires, but I'll try pushing it from that way to access the bulb. Thanks.
And iosmart - I'll give that forum a search, thanks!
Old Sep 22, 2004 | 05:07 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
its easy... there is a tool you can buy, or make with tough metal clothes hangers...
basically, there is a hook at the end of a rob about 6-10 inches long... you place this tool at the left & right bottom edges, once the hook locks in place, you just pull straight out.
Old Sep 22, 2004 | 05:15 PM
str8ridin's Avatar
05 E55
Hmm, cool, I'll check the dealer...and if it's too expensive, then I'll return it! Or keep it just in case another bulb goes...thanks!
Old Sep 22, 2004 | 06:57 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Recommend against using the tool on a CLK.. the dash material is very susceptible to rips. What BrklnBenz wrote is the best... remove lower dash panel, push IC out from behind.
-s-
Old Sep 22, 2004 | 08:35 PM
mmgrad's Avatar
the tool itself is pretty cheap... around $10-20 for the set.
But, scorchie is right... the material on the dash is very soft, and can tear if not careful using tools around it. So far, I've removed my cluster about twice and I haven't had any issues with the dash.
just be careful... thats all I can say
