No click, no crank, no start
Remove the serpentine belt and try turning the engine over at the crank. I believe the crank pulley uses a 27mm bolt. Put a socket on the crank pulley bolt and rotate the engine clockwise (make sure the transmission is in Neutral and the wheels are chalked). You'll probably need a 1/2" breaker bar, since you'll still have compression (I hope). LMK how it goes.
Good luck!
