ML 55 flow sensor in CLK 430
Got a lot of question since I have my CLK 430 from few weeks now.
As I planned to replace the 430OEM AIRBOX by the 320 AIRBOX (see other thread) following the positive inputs I have found in MBWORLD.
I was wondering it it would be an interesting mod for performance to switch the 430 OEM flow sensor by a one from ML 55 AMG. What do you think?
Found one for sale, and since it is the same configuration that the one I plan to install (the 320 airbox is more or less the same as the ML 55 airbox) could be a good way to gain some power for minimal investment.
If it's good for perf (knowing I will do a chip / ecu tuning after that).Is it easy to change to swap the pieces? Are both sensor fitting the engine the same way or should I expect getting into trouble and difficulties? I don't know if someone did it before.
Thanks for your feedback
Julien
