A/C Keeps going out
Old Nov 2, 2004 | 05:00 PM
proform's Avatar
Ferrrari 458 Lamborghini SL 570-4 Mercedes CLS63
A/C Keeps going out
My A/C stopped blowing cold air so I brought it to the dealer to have it fixed (they managed to crash the car while fixing it!!) It has been blowing ice cubes since (about 2 months) and then about 20 minutes ago...Bam warm air!!!! Any ideas out there? Should I Plug in my scanner?
Old Nov 2, 2004 | 05:05 PM
proform's Avatar
po450 code came up
Old Nov 3, 2004 | 10:12 AM
TresX's Avatar
EVAP Emission Control Pres Sensor Fault....or so it says in the book. You're better using your climate control diagnostic functions to check for the problem.
As a matter of fact, look up the values for 5 and 7 and report back. (I've got LOTS of experience with CLK A/C)
Old Nov 3, 2004 | 11:32 AM
proform's Avatar
OK...Thank You!
Old Nov 3, 2004 | 12:33 PM
proform's Avatar
I guess its still under warranty so the dealer has it now...I will let you know what they say....thanks
Old Nov 3, 2004 | 05:24 PM
midget fidger's Avatar
E550 Coupe
https://mbworld.org/forums/mercedes-tech-talk/71756-what-else-mb-hiding.html
Have you ever seen anything like what I talked about in this thread? Out of 938 views, no one has heard of it and since we're all MB Fans, we just deny that they'd ever do something like that.
Old Nov 8, 2004 | 05:38 PM
TresX's Avatar
Originally Posted by iosmart
https://mbworld.org/forums/showthread.php?t=71756
Well I checked out my handy 208 repair cd and it seems you stumbled upon the version coding feature of the climate control module. You can change different settings there.
Old Nov 8, 2004 | 05:48 PM
E550 Coupe
How do I get to it? The first time was accidental but I'm sure someone else might run into a similar situation down the road. I think there was another guy on the board with the same EC problem and he solved it by spending the $500
Old Nov 9, 2004 | 01:35 AM
TresX's Avatar
unfortunately the instructions are pretty extensive....and I can't just cut and paste the text from the program....
Old Nov 9, 2004 | 04:09 PM
E550 Coupe
Well...just how to get into it I guess then, not how to do stuff inside of it. It only took a few button presses to get in. What about if you press the Print Screen button on your keyboard, paste it onto a word document, and email the file to me?
Old Nov 9, 2004 | 04:32 PM
TresX's Avatar
here you go...
File Type: bmp
Old Nov 9, 2004 | 04:43 PM
E550 Coupe
Excellent, I'll try it out later.
If that's bittorrent you have, Azureus is a really good client: http://azureus.sourceforge.net/ Screenshot: http://azureus.sourceforge.net/img/s...y_torrents.png
Old Nov 9, 2004 | 04:55 PM
TresX's Avatar
It's burst actually that I'm using. Does Azureus offer anything special?
Old Nov 9, 2004 | 06:21 PM
E550 Coupe
I'm not sure about burst but it shows two windows open for it. Azureus manages everything in one window and you can set global upload caps. You can prioritize different torrents and there's a plugin called SafePeer that connects to the PeerGuardian database to ban risky IPs (riaa/mpaa).
Here's SafePeer: http://azureus.sourceforge.net/plugi...lugin=safepeer
Old Dec 13, 2004 | 05:55 PM
E550 Coupe
TresX, the instructions in that picture don't bring me to what I accidentally found my way to a couple months ago. I didn't get a chance to try your instructions up until now...another member is having similar problems with his AC.
https://mbworld.org/forums/clk-class-w208/91595-i-am-not-able-turn-off-ec-light.html
Old Dec 14, 2004 | 01:48 AM
TresX's Avatar
Try to explain to me exactly what you saw when you entered the mode and I'll look it up for you when I get a chance.
Old Dec 14, 2004 | 07:02 PM
E550 Coupe
hey,
that screenshot seems like the same thing i entered. all i remember is that the left said 1 and the right said 232 and i could change both values by pressing up/down. i'm not sure if they have something similar but with a different way to get into it?
Old Dec 17, 2004 | 08:47 PM
napoli's Avatar
1998 CLK 320 RED
Talking Wow
Wow..you guys seem to know a whole lot about CLKs..I have a post out on electrical systems and sensors...questions. My A/C compressor was just replaced.
I have a feeling that I need to get as much replaced on my 1998 320 as I can in the next 6 mos, as I have a Starmark unitl then
I would also be interested in where to obtain a detailed breakdown of sensor codes
