CLK 430 M113 bad acceleration, sluggish, limp mode
I have no bad air intakes, everything is sealed. The way I would describe the acceleration would be lower RPM it has good torque but until you give it throttle it just feels very slow and heavy on the acceleration, yet it still maxes out RPM, no problems. No sudden stops mid range or at the end.
The previous owner changed the acceleration sensor in the hood, the one with the hook attached to it.
Fuel pump and filter were also switched a couple months ago. Also, the car runs on LPG aswell, but the symptoms occur on both fuel types. on LPG it is a bit slower (when everything works) and on normal petrol, it runs fast.
What else can I be looking for?
edit: and you have it on S, not winter mode? I feel these Mercedes are pretty sluggish at times unless you are hard on it, sometimes.. but I don't have any errors AFAIK
