front window regulator sliders
Old May 14, 2024 | 11:23 AM
Marvel06's Avatar
2003 CLK 320 convertible
Hi all,
Yesterday whilst poking around on my car, I had the drivers side door panel off to do a little refurbishing and while I was in there, I noticed that one of the slide bushings on the bottom window guide rail was broken in half. It must have just happened because when I rolled the window back up, it did not go back all the way. There was a gap at the top and it was sitting crooked in the door. It is the rear slider that is broken. The two halves are at the end of travel in each direction. Has anyone else had this happen and can this slide bushing be replaced or do you have to replace the whole regulator assembly? I haven't taken any pictures and it's raining right now, but I will try to update with some pics later.
Thanks!
