2000 CLK320 Soft Top Question
Purchased a new to me, 2000 CLK320, in excellent shape. Soft top would go down with some assistance and putting it back up was hit or miss and it finally quit a couple days into owning it. After some wrenching, I have found that the pressure relief valve was open and the hydraulic reservoir did not have enough fluid in it. I assume some neglectful ownership and poor workmanship, but who am I to judge. My first thing to do is refill the reservoir to the appropriate level and close the pressure relief valve, and cross my fingers. My questions are:
Do I need to purge/bleed the hydraulic system once I refill? What is that process?
Do you think it could really be that simple of a fix?
Do I need to reset the system for it to cycle properly as I have been manually opening and closing?
I do see that I will need to get some of the cylinders rebuilt and that will be a project for this winter, they are not in terrible shape, but if this fixes the problem, rebuilding will be a priority for it to be in tip top shape.
I appreciate all the insights and comments and look forward to hearing what the expert owners and wrenchers have to say.
Neeilly
No purge / bleed necessary. Top Hydraulic has an excellent video
One thing no one seems to talk about is the bottom anchor for the case lid (storage) cylinder becoming loose. When this happens the lid doesn't open far enough and the latch will cut the soft top. The stud is secured by a nut that isn't easy to get to. I drilled a hole in the side of the flange so I could get a wrench in there.
I bought a seal kit for two cylinders that were visible leaking (you can smell the oil) and if I pulled up the rear seat there was pool of 1/2 cup of oil collecting.
You’ll need to refill the reservoir, then don’t forget the trunk cover needs to be closed before it will operate again🤣
I also now have a trunk access hole behind the license plate for easy opening.
