2003 CLK 430 Cabriolet - sluggish acceleration and P0171/P0174
96,000 miles
CEL light comes on 3-5 driving cycles after throttle reset procedure.
The freeze frame data indicates the CEL happens at idle conditions when warm.
P0171 code and sometimes P0174
left and right bank lean
What I have done so far:
1. replaced fuel filter
2. validated fuel pressure 55psi and stable
3. replaced throttle position sensor
4. Replaced map sensor
5. replaced 4 vacuum hoses
6. validated idle vacuum is 15.5inHG
7. validated gap on spark plugs
8. replaced mass air flow sensor
9. validated intake runner flaps operating properly
10. used Techron fuel system cleaner
11. validated that all fuel injectors cycling
All of these items were relatively inexpensive and easy to replace with Mercedes parts and would recommend these updates to anyone else. I have noted significant overall performance improvements with the car including improved performance. But I am still seeing the CEL and what seems like a 25-50% power reduction from 1000-3000rpm after 3-5 driving cycles from fresh TPS reset.
What should I try next?
A. Crankshaft Position Sensor
B. Camshaft Position Sensor
Thanks,
Andy
Final solution: fuel injector replacement, but it was likely just the seal on cylinder number five, see the debris in the port of the attached photo. Directly after replacement the short term fuel trims had major -25% adjustment to reacting for the lean condition correction.
And the oxygen sensor rich condition at startup as shown in the graph that reverted to proper operation.
The latest replacement is the intake manifold gaskets and knock sensors. Have noted significant improvement in idle, and all clearance of codes.
note the before and after smoothing of ignition advance at idle (when the CEL was happening). I believe the knock sensors were the root cause, but not sure as I completed both services at once.
New on left, and old is 1/4” shorter and collapsed. I also replace transmission mount at the same time. Well worth the money and effort. ($200 total and about 1-1/2hr to change each)
