Check your coils guys
Subscribe
Sep 14, 2024 | 11:17 AM
Had a strange running issue that appeared as if the motor mounts failed. Under normal cruise, the CLK430 seemed fine but would have a rough idle at a stoplight or at operating temperature.
The number 5 ignition coil was arcing against the engine block, appearing as a bad spark plug wire. Turns out there was a small crack in the hard plastic seam where the boot connects. The arcing can be seen in the dark.
Car is on original coils still and I just replaced the one bad one. I have the other 7 in a shopping cart ready to go. The car runs like new after the replacement by the way.
Reply 0
Sep 15, 2024 | 10:00 AM
That’s good to hear you found this issue and I’ll check mine. Usually it’s the motor mounts, as most of us have replaced them. My CLK430 feels like a completely different car after replacing mine.
Reply 0
Subscribe
Currently Active Users (1)
