Climate control panel screen malfuntion
Old Sep 15, 2024 | 04:10 PM
austin94's Avatar
2001 E320, 2010 E350 Sedan, 2009 E350 Wagon, 2014 E350 Coupe, 2015 ML 350
Hey everyone, 2000 CLK 430 cabrio. Climate control screen displays as normal when car is started, then after 5-30 seconds it begins blinking then it shuts off, deactivating blower motor and all HVAC EXCEPT rear defrost? That light will stay lit.
cleaned electrical connectors, checked fuses, anyone else ever experience this?
Old Sep 16, 2024 | 04:41 AM
Scimitar1968's Avatar
2001 clk200 avantgarde komp. convertible
Yes. Carried out all the checks as you have done. Took it to an Auto Sparks. Blower Fan replaced. £££. Same problem. Back to trial and error checks.
In the end it turned out to be a fault on the Control Panel Switch on the dashboard. Heater Control switch shorting out when warm. Part no longer
available from Mercedes in the UK, as are most parts for the W208. Had to search the scrap yards for a replacement that worked. £30. Job done.
Panel and Switch Unit are just Push Fit.
