Help needed - what could be wrong with my cd changer?
Old Dec 1, 2004 | 03:08 PM
TonyD's Avatar
2000 CLK430
All of a sudden, the message says "No CD Changer". Thanks in advance for your input.
Old Dec 1, 2004 | 03:58 PM
Benzoxtc's Avatar
2002 CLK 430/2002 325i
Display error
Try turning the car off (or key out of the ignition), wait about a minute and then put the key back into the ignition (or turn the car back on). Can't explain to you what really is happening but I've had occurrences where only half side of the speakers work and by taking the key in and out of the ignition has fixed the problem. Hopefully it works for you as well.
Old Dec 1, 2004 | 04:15 PM
TonyD's Avatar
2000 CLK430
Dealer said its a bad CD changer and needed to be replaced - hmmmm
I'm not sure if that is all to it...
Old Dec 1, 2004 | 04:37 PM
CHB's Avatar
CHB
'79 300D, '85 300Dt, '99 CLK430
When this happened to me, i took out the changer, and put it back in and it worked fine
Old Dec 1, 2004 | 04:42 PM
tux2's Avatar
r170
same here changer problem
but only on mine, the cart get stuck inside the changer.
Old Dec 1, 2004 | 05:02 PM
TonyD's Avatar
2000 CLK430
Is it pretty simple to try and remove the cd changer? Thanks again...
Thanks for all your inputs.
Old Dec 4, 2004 | 11:53 PM
CLK430ROB's Avatar
Mine is doing EXACTLY the same thing. Says No CD Changer and the magazine doesn't want to eject either. I dont have time to check it out yet, either.
Rob
Old Dec 6, 2004 | 01:40 AM
TonyD's Avatar
2000 CLK430
My CD Changer is back!
Removing the fuse and re-entering the radio code is the savior! Thanks to everyone for their suggestions!
Old Dec 6, 2004 | 02:28 AM
The Kingfish's Avatar
Happens to me all the time too which is why I use my iPod instead. Never use the CD changer anymore.
Old Dec 6, 2004 | 05:38 AM
CLK430ROB's Avatar
Hmm.. can you elaborate? I have the COMAND and it was installed by Steve.
Thanks in advance,
Rob
Old Dec 6, 2004 | 12:12 PM
TonyD's Avatar
2000 CLK430
To CLK430ROB and The Kingfish
CLK430ROB, I don't have COMAND. All I did was to locate the fuse for the radio, took it off and then put it back in. When the radio was turned on, it asked for the radio code. Put in the radio code and that was it - the CD Changer was recognized again.
The Kingfish, what link did you use to work you IPOD in? Thanks!
Old Dec 8, 2004 | 03:45 AM
CLK430ROB's Avatar
Thanks for the Info..
Being a lazy *** and not wanting to look for the radio fuse, do you happen to know where it is by any chance?
Also.. if your reading STEVE. If I pull the fuse on the COMAND... will I need a radio code? I have your Euro Comand that you installed for me, but I never recalled having to enter a code or you giving me one.
Thanks in advance,
Rob
Old Dec 8, 2004 | 10:25 PM
NVDR's Avatar
CLK430
TonyD, If you dont mind me asking, what radio code did you use to make it work?
Old Dec 9, 2004 | 12:35 PM
TonyD's Avatar
2000 CLK430
NVDR - call your dealer (or nearest one) they should be able to give you
the right code for your radio.
Old Dec 9, 2004 | 05:44 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
there is a unique radio code for your particular head unit... it helps prevent a stolen stereo from being used.
Old Dec 9, 2004 | 05:51 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Thanks in advance,
Rob
The COMAND does not use a radio code... so pull the fuse at your leisure.
-s-
Old Dec 10, 2004 | 03:07 AM
CLK430ROB's Avatar
When refering to the fuse. Are we talking about the fuse that is behind the radio? or the fuse from the fusebox?
Thanks,
Rob
-s-
Old Dec 10, 2004 | 03:37 AM
scorchie's Avatar
Thanks,
Rob
Well, I was only referring to the code requirement, of which there is none. You can pull either fuse and you still won't need a code. The fuse behind the COMAND is for whatever the COMAND supplies power for (such as CD changer or antenna stuff). The fuse in the fusebox supplies power to the COMAND (and of course, to whatever the COMAND supplies as well).
-s-
Old Dec 10, 2004 | 04:04 AM
I have COMAND, which comes with an AUX-IN jack.
Old Dec 10, 2004 | 05:32 AM
TresX's Avatar
Thanks,
Rob
If you're really that lazy....just disconnect your battery and reconnect it. Of course you'll have to reset some other things as well (IE sunroof, windows...etc)
Old Dec 10, 2004 | 08:47 PM
CLK430ROB's Avatar
Lol
Yeah.. i a pretty lazy *** ****.. :p
Old Jan 10, 2005 | 07:53 PM
CLK430ROB's Avatar
I tried this last night
Removing the Fuse for the Radio and putting it back, but it still does not see my CD Changer. It seems that it did'nt reset anything. All my presets were still saved on the COMAND and it was as if it always had power. I removed fuse #10 (15amp) under the hood. Did i do the right one? This is a COMAND that steve installed.
Thanks,
Rob
Old Jan 10, 2005 | 08:27 PM
TresX's Avatar
Thanks,
Rob
If your presets were still saved, then your radio did not lose power when you pulled the fuse. Either Steve ran another constant 12v power supply to the radio (highly doublful) or you did not pull the correct fuse. Just unplug the battery...it'll be a hell of a lot easier.
Old Jan 11, 2005 | 06:04 AM
CLK430ROB's Avatar
Wont I have to reset a bunch of crap if i unplug the battery?
Thanks,
Rob
Old Jan 15, 2005 | 07:20 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
This happened to me twice, and when I took the car to my dealer, they replaced the whole unit both times while I was under warranty. It hasn't happened again.
