Hello..
Can anyone tell me if these rims will fit my car??? I have a 2002 clk-55 and the rims are coming from a 2000 SL500. Thanks!!!
4 ---lowenhart 8dz 19" chrome wheels 512-985-31mc-br5, and 4 tires used for about 4000 miles on a 500 sl mercedes, tires are nitto 555
sizes are 2- nto-245/35/19-zr-555
2- nto-275/30/19-zr-555
the tires are a little larger than you'd like... but, it wouldn't be difficult to fit on...
as for the wheels, you'd have to check the wheel's offset... if its 35 or greater, you can make it fit...
scorchie
close
How low your car is going to make a big difference on whether it rubs or not.Originally Posted by Al!!!!!
Hello..Can anyone tell me if these rims will fit my car??? I have a 2002 clk-55 and the rims are coming from a 2000 SL500. Thanks!!!
What are the offset of those rims? I think they are around ET30, so it should be an OK fit. Going too high will make it rub on the inside with that size tire (I run 245 on the front with ET30, 285 on the rear with ET33... the ET33 is a bit too high of an offset... 31 would be just about right).
-s-
