Wiring help/radio code info needed.
Old Dec 19, 2004 | 06:08 PM
King320's Avatar
03 C32 AMG
Arrow Wiring help/radio code info needed.
Hey guys,
Im doing some of the SRX install tonight. So far i have fit the radar detector in the front behind the grille and now im trying to run the wire into the cabin of the car. I've already disassembled the fuse box, and am attempting to pass the wire through there and into the cabin as the guys on slk32.com did with an SR1. here's the link...
http://www.slk32.com/pages/passportSR1/sr1-2.html
My questions are these
1)has anyone run wires from the engine compartment into the cabin before? any input on where to go through the fusebox? i really dont want to do anything that will open the possibility of water damage, etc. It doesnt look like the SLK guys really took that into account if they left the thing wide open like that after making a hole in the side. Also does anyone have any general advice about messing around in the fuse box? any huge donts??
2) Can i get my radio code from my dealer over the phone if i give him the VIN number? I may have to disconnect the radio before this is over. My audi never asked for the code once it was reattached, but im thinking this one might.
I'm taking pictures as i go along, so if you need pics to look at to offer advice just ask.
Old Dec 19, 2004 | 10:56 PM
rajah996's Avatar
CLK55, CL500, Q45
1) You might want to consider making a hole in the firewall to
bring in whatever wires you want. Just make sure to put some
of that foam in a can spray once your done, to make it nice
and air/water tight.
2) You might try to call MB on the phone to get the code, if they
have you down as the registered owner and you give them the
VIN, they should be able to help you.
Old Dec 20, 2004 | 12:27 AM
midget fidger's Avatar
E550 Coupe
i think someone on here did some kinda pass using a coat hanger to hook up a cell phone. wait no, it was for XM satellite - see if you can find it, might be helpful
Old Dec 20, 2004 | 06:58 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Originally Posted by King320
Hey guys,
Ummm, the R170 SLK and W208 CLK are pretty much identical in this regard (and in most others as well). There's a huge hole under the fusebox where all the wires pass into the passenger compartment. You can just pass yours through the existing hole. No need to make any holes, or do anything that will permanently alter your car. If you take the carpet out on the driver's side and the kick panels etc., then remove the fuse box, you can see right through there.
But, why are you going through all that hassle? To hook properly into the fuse box you will need the proper connector. You can just go to the back of the cigarette lighter, make a Y-cable using standard 1/4" spade connectors, and be done with it. This has been covered a lot on this board, you may want to search on it if you don't understand the concept.
I think your dealer would be the best source of the answer for that question, you may wish to call your dealer. If you've ever had any work done on your car and you have the receipt, the radio code should be printed on the work order.
-s-
Old Dec 20, 2004 | 07:01 AM
scorchie's Avatar
Everyone might want to consider never making holes in the car that aren't necessary... and I've never heard of it being "necessary" to make a new hole. There's a huge hole where all the power wires pass in from the fuse box. Why make another one?
-s-
Old Dec 20, 2004 | 05:55 PM
King320's Avatar
03 C32 AMG
Done with the install. everything went smoothly and i didnt need to disconnecty the radio.
Old Dec 21, 2004 | 02:26 PM
E550 Coupe
that was pretty quick, got any pics?
Old Dec 21, 2004 | 05:17 PM
King320's Avatar
03 C32 AMG
yeh, i only did the radar part, no laser stuff yet. I took pics and will post them later tonight
