W208 convertible top system check issue
Old Jan 21, 2026 | 04:21 PM
tomenglin's Avatar
2001 CLK320 Cbrio
I am trying to solve my intermittent issue of the top module indicating a fault at key on that will not allow top operation. (Top switch does not go out after key on). I have checked all of the microswitches and found them all correct at both closed and opened positions. Does anyone have a list of the modules (in order) that are checked by the top module when going through the system checks at key on?
Serndipity?
Old Jan 22, 2026 | 12:01 PM
AllenGreenman's Avatar
2002 CLK320, 2016 W212 E350 4Matic Sedan, 2020 Royal Enfield Interceptor 650
Serndipity?
Maybe some of this will help
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 26, 2026 | 06:28 PM
tomenglin's Avatar
2001 CLK320 Cbrio
Does anyone have a good wiring diagram for the CanBus on the W208 Cabriolet?
Old Jan 28, 2026 | 11:39 PM
tomenglin's Avatar
2001 CLK320 Cbrio
What I am looking for is a list of the CANBUS signals from other modules that the top Computer N52 must receive to enable top operation on system power up. I am also looking for the order of the CANBUS module connectors in the X30/7 junction connector. This is for troubleshooting of my 2001 CLK320 Cabriolet. Anyone?
Old Jan 29, 2026 | 11:36 AM
Hi - here's what I have, maybe some of this will help.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 30, 2026 | 03:55 PM
tomenglin's Avatar
2001 CLK320 Cbrio
Thank you for your responses Allen. All good information. But all my switches and wiring test OK. And when the system works, all is validated. The issue is isolated to the System Check" that the computer performs on "key on". So if I could find out what conditions the computer needs to see during that 1 second test period when the ignition is turned on, I could begin to make some progress.
Old Jan 31, 2026 | 09:26 AM
andy_breuer's Avatar
CLK 430
Here’s an idea you might try next: remove the fuse for the convertible top control module completely to see if the issue with the other systems persist. If you continue to have a host of issues, the fault is not likely within the convertible top system. Have you checked security or key fob systems? I’ve heard they can go bad sometimes, but are relatively easy to replace.
