Canvas seam separation
Old Feb 2, 2026 | 06:56 PM
Cathunberg's Avatar
CLK 430 convertible
Hello,
The convertible top of my 2002 CLK is starting to separate at the seam by the C-pillar. Wondering if any forum members have advice for repair?
c-pillar on drivers side
Old Feb 3, 2026 | 05:54 AM
andy_breuer's Avatar
CLK 430
Yes, I’ve had some good success with repairing the seams on my black top which were doing the same. 1) loosen and retract the top slightly, ensure that the back part of the top can lift, then turn off the car 2) use superglue to glue the joint together, and let cure 3) use tape to mask the joint 1/4” wide and apply black RTV and trowel with finger tip, remove tape while RTV is still wet
Old Feb 10, 2026 | 11:00 AM
tomenglin's Avatar
2001 CLK320 Cbrio
Be sure you use a flexible fabric glue as this section must bend when retracting. I have had good results using Aleene's Super Fabric Glue available on Amazon. Clamping that area is a challenge. I stuffed cloths behind the seam and leaned a heavy board against the outside.
Old Feb 26, 2026 | 01:35 PM
CLK 430
Here is what my seam looked like after the superglue/RTV application with tape mask.
