"check engine light" question *HELP*
Old Jan 10, 2005 | 06:09 PM
2001CLK's Avatar
2001 CLK320, 2003 E320
Had my check engine light flip on today and I immediately contacted the dealer. \They responded by first telling me to unscrew my gas cap and release any pressure build up which was probably the cause of the tripped sensor. I did that and still the light was on. The service advisor told me to drive around for a few days and see if the sensor would reset itself if not to bring it in.
My question is… is this bull****?? What are the possible problems for the “Check Engine” to go on..?? Should I even be driving it? I don’t want to make the problem worse.
Any info is greatly appreciated.
Old Jan 10, 2005 | 07:03 PM
rajah996's Avatar
CLK55, CL500, Q45
He probably figured you were one of the elderly crowd who
fills up gas, and didnt tighten the cap. Yes if you dont make
it tight, you will loose pressure in your tank, causing a check
engine light. Seriously though, it sounds like something else.
Mine just came on last week for a few days, and I found out
that its caused by a MAF which is on its way out, so I have
the part on order.
Old Jan 10, 2005 | 08:21 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
If the CEL is activated because of a fuel system leak (vapor canister, loose gas cap) or bad readings from the O2 sensor, and these errors are later corrected, the light will go out after a certain amount of time... until it happens again. If it goes out and comes back, or doesn't go out, it's best to bring it in and have the codes pulled to tell you what it is.
I had a single marginally bad O2 sensor that on hot days, would light up my CEL when I got on the gas. The next day it would go out for a while. I eventually replaced it myself. Also I had a leak in the vacuum canister line. This starts off with a blinking empty fuel tank light (same as with the loose gas cap) and then turns into a full blown CEL.
-s-
Old Jan 12, 2005 | 06:56 AM
NVDR's Avatar
CLK430
mine was caused by a gas cap not tightened, after driving more than 100 miles it is gone. no more cel.
Old Jan 12, 2005 | 08:54 PM
2001CLK's Avatar
*Update*
After reading other threads on this I decided to unplug and plug the MAF and sure enough the CEL went off.
You guys think I should still take it in? Do I have a bad MAF?
Thanks in advance..
Old Jan 14, 2005 | 01:58 PM
Ironmudd's Avatar
CLK430 designo
Mine did that and they said it was the oxygen flow sensor when I took it in. It was under warranty, so no big deal. Guy told me to replace the air filters and that would keep it from happening.
Old Jan 15, 2005 | 06:58 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Ahh, all this electronics. In the good all days, all you had was an oil pressure light, if you have oil in your engine, what else can damage it?
My wife's mini van check engine light came on at 50,000 miles, and the dealer wanted $240 for the oxigen sensor, so we droved 70,000 miles more until we sold it with the check engine light still on!
Old Jan 15, 2005 | 09:47 AM
Chappy's Avatar
AMG
Thanks in advance..
Do you have stock air filters?
Old Jan 15, 2005 | 03:55 PM
2001CLK's Avatar
yep my airfilters are stock...
Old Jan 15, 2005 | 09:42 PM
rajah996's Avatar
CLK55, CL500, Q45
ok, does anyone know how to change the MAF? I am not sure
where it is located, or how to fix it, but have a bit of tech
knowledge. If someone can explain it to me, I am sure I can
figure it out.l If anyone can help me out, just post up the
directions, or PM me. Thanks in advance!
Old Jan 16, 2005 | 03:19 AM
2001CLK's Avatar
It looks relatively simple to replace. It’s located between the air hose and air box. Good Luck!
Here's the MAF circled in red.
Old Mar 1, 2005 | 10:36 PM
ryhi's Avatar
UCF21
what are other problems causing the gas light to blink? mine still blinks and i checked the gas cap.. CEL still on too..
