Wheel spacers
Old Feb 18, 2005 | 01:21 AM
smalldog's Avatar
clk
Wheel spacers
Anyone got a set of weel spacers they're trying to sale. I wont to bring my rear wheels out more. Rims are 19x8.5.
Old Feb 18, 2005 | 03:27 AM
clkal's Avatar
01' CLK55
contact any dealer that carries H&R. H&R makes hubcentric spacers.
Old Feb 18, 2005 | 07:42 PM
smalldog's Avatar
clk
Would these be ok it I got the longer studs.
http://www.bekkers.com/Merchant2/mer...ry_Code=bmrims
Old Feb 18, 2005 | 07:55 PM
smalldog's Avatar
clk
what about these
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Feb 18, 2005 | 08:49 PM
clkal's Avatar
01' CLK55
the manufacturer is NOT the important thing you should be focusing on right now. You should be figuring what offset your rims are, and figuring how many mm's you want to space them out. By doing this, you also need to find longer bolts.
Old Feb 19, 2005 | 05:54 AM
mtimmy's Avatar
W208 55 & R170 230
check evosport they have it instock., but pricy
parts4vw also has them too... a lot cheaper..
35mm offset 8.5 you need at least a 10mm
Old Feb 19, 2005 | 12:59 PM
smalldog's Avatar
clk
Thanks......
Thats 10mm each side......correct?
Old Feb 19, 2005 | 02:14 PM
mtimmy's Avatar
W208 55 & R170 230
If you have 35mm offset rim,.,. 10mm each side is what you need
H&R makes hubcentric 10mm fits perfectly for you,. parts4vw.com has it in stock at a vary low price., with bolt too
get the H&R 12mm longer bolts.. fit perfectly!!!!
they are like 2.xx each
I know, because I have JUST added spacer to my rear with the new rims to clear the rear caliper
Old Feb 19, 2005 | 05:28 PM
smalldog's Avatar
clk
link my to the ones you ordered. no mercedes in the selection.
Old Feb 19, 2005 | 05:31 PM
mtimmy's Avatar
W208 55 & R170 230
http://www.parts4vws.com/catalog/pro...umber=20255571
Old Feb 20, 2005 | 12:30 AM
smalldog's Avatar
clk
[QUOTE=mtimmy]http://www.parts4vws.com/catalog/pro...umber=20255571[/QUOTE
Are your rims aftermarket or oem. The info states the following...Note: Spacer to wheel fitment needs to be checked prior to instalation. Most aftermarket wheels will NOT work with these spacers. My wheels are ADRs. I don't know if these will work.
PS....Thanks for all the help
Old Feb 20, 2005 | 01:39 AM
mtimmy's Avatar
W208 55 & R170 230
dosent' matter if they are or not, if you have 35 offset,. with 8.5 width., this 10mm will work perfectly fine with you
