must i go Stagger?
none
must i go Stagger?
i really wanna go stagger
but the rims i "can" afford only come in 19x8.5 in front and the rear.. would this work??
what offset should i get for these?
thanks in advance!
thanks in advance!
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
first of all, what u need to do is u need to roll up a joint, smoke it and relax. then, u should give a call to peter@wheelexperts and he will tell u what u must and not must do.
1 Post
'02 SLK32 AMG
You could stagger the tires but not the rims. With your 19x8.5s, you could put 225/35s on the front and 255/30s on the rear. The sizes aren't common, but I think Pirelli PZeros are available in both sizes.
R129 SL55 AMG & W208 CLK55 AMG
i have a set of 18's, but the sizes are as follows:
front 8.5x18 ( 235/40 ZR18 )
rear 9.5x18 ( 265/35 ZR18 )
i think 235's in the front for 19's is better otherwise you will wear out the inner treads like a ***** !!!
