TV tuners How much??
2006 Edition CLK 280 Coupe
This is the info I got from Steve @ MBenznl.com
The W209 Euro DVD comand can be used to hook up a MOST based TV tuner. We can offer a TV tuner - new OEM (PAL/NTSC compatible), with OEM wiring harness from comand to TV tuner and either aftermarket 4way diversity antenna or original antenna amplifier with TV connections and wiring - for either Euro 1425 or for Euro 1600, depending on what antenna Steve will use.
Hope it is useful
Hope it is useful
Do they Euro Comand and U.S. Comand use the same harness...What I am asking is this....00' CLK430 with Nav already installed, if I were to swap that unit with a Euro unit (to get the TV and DVD function)...would it plug into the same harnesses?
2015 E250D
The harness is the same for either comand. You can activate the button on your USA comand but you need to have access to a SDS system with developer mode which is rare in the states. I can do it in Houston or STeve can do it if you are near his visits. If either of these are not possible, then you will have to exchange comands.
W203 slightly modified
Originally Posted by Chi500
Does anyone know where i can get a tv tuner. Last time i asked, Steve said he doesn't have any more of them.
