Climate Control Problem...
Old Feb 14, 2006 | 12:47 PM
mbfan77's Avatar
I have a 2004 CLK500 with dual automatic climate control.
When I turn the passenger temp up to "HI" I feel heat come out of the vents, but when I lower the temp to 89 or 88 degrees the air is cold
Is this normal?
Is there something I am doing wrong?
Old Feb 14, 2006 | 04:32 PM
dkim's Avatar
2022 911 c4s cab, 2022 Lambo Urus
that reminds me of a problem i had too. Cold air was coming out when the heat was turned on. I had the settings on 77 degrees and relatively high fan. The air was cold.
I did notice the blue colored controls in between the center vents and turned it so that it would be closed. I dunno if that's what did it, but it blew out hot air after that.
I could be dead wrong. I actually have no idea what that center blue control does. Does it close out the outside air or something?
