Command Retrofit/ICelink Problem. Please Help
Old Apr 1, 2006 | 09:30 PM
zp91hbk's Avatar
Hey guys
Just recently purchased a CLK55 AMG 04
Ordered Euro Nav and Icelink for my IPOD
Had them installed today from a very tech savy person.
I watched him install both the Command and the ICELINK and he did it 100 percent right (i made sure we followed instructions)
The Command unit works as far as NAV/CD/ and Radio but there is a major problem.
NO SOUND WHATSOEVER, and my stearing column and instrumental cluster is not recognizing the stereo anymore. VERY WIERD.
Will a trip to mercedes for a coding get this back in working order?????
ALSO, my ipod notices my icelink and mercedes, but the Command does not recognize a cd changer (icelink) therefore I cannot control the ipod.'
Will a coding help this also? Please let me know your thoughts on what I should do. Thanks!
Old Apr 2, 2006 | 06:57 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
...these 2 things don't go together...either the comand got installed by a not so very tech savy person or everything does work as it is suposed to do...
In short: HAVE HIM CHECK THE C CONNECTOR as that is not connected properly...the C connector has the wiring for CANBUS (which is why the comand is not recognised by the IC anymore, why it doesn't turn on/off per ignition key and why the NAV does NOT work properly due to the fact that it doesn't get a speedpulse) and the C connector has the WAKE UP wire plus the POWER and GROUND for the CDc which are the cause of a failing D2B ring and thus NO SOUND from the BOSE AMP.
greetingz,
