Help! Need Remote turn on for AMP
Does anyone know where i can tap into the remote turn on lead from the head unit? Or does it even exist since the remote-on can be sent through D2B?
Or if anyone knows an easy ACC wire i can reach in the trunk? I don't mind using that.
Thanks,
I used the blue wire first and realised its a constant power. Then I connected the black wire from head unit to remote turn on for the new amp. Works fine with CDC and CD player but when I switch to radio, amp is powered on but no sound from the sub. Can anyone tell me what color wire should be used for remote to connect to the amp? Its a 2005 CLK500. Thank you in advance
all i had to do is to remove all other components on the fiber optic loop, unplug them, and install a fiber optic adapter bypass to bypass them without interruption in the fiber optic track
bow car doesn’t need to spend 8 min waking them up in the absence of comand unit.
