My power seat and steering wheel are not working
Old Nov 3, 2006 | 03:35 PM
Black209's Avatar
My driver power seat is not working so is the steering wheel.. i brought it to the dealer last week they changed 2 fuse but it doesn't seem to work.. has anyone encounter this problem??
if my warranty is out will i be charged for repairing this problem??
Old Nov 3, 2006 | 10:31 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
Check the wire harness at the base of the driver's seat - you probably broke the plastic fastener with your foot and the wire came loose. Once this wire is disconnected, neither will move.
Old Nov 5, 2006 | 01:20 AM
Black209's Avatar
Thank you Frisco you're actually right the wiring was loose...
Old Nov 6, 2006 | 10:16 PM
Frisco's Avatar
You are very welcome - I broke mine a long time ago and the wire comes loose every couple days
Old Apr 15, 2009 | 02:32 PM
MikeDC's Avatar
2013 E550 Cabriolet; 2004 CLK500 Cabriolet Designo (sold)
I love this forum
Several months ago my power steering adjuster stopped working. A couple days ago, while running a search on warranties, I came across this thread. Tried my power seats and they weren't working either. Voila, it was the wiring harness! Fixed the problem from advice I just happened across in a three year old post!
Old Feb 26, 2010 | 10:57 AM
hkim201's Avatar
02 CLK320
how much will it cost to get it fixed? i think mine has same problem...
Old Mar 18, 2011 | 01:05 PM
zdfun's Avatar
2005 CLK 500 Coupe
Thank you Frisco! That's exactly what happened to my car few days ago, and I was little bit worry, but I just touched the harness this morning, and it is working again.
Old Mar 18, 2011 | 06:30 PM
Clkboi's Avatar
CLS550 4Matic
Ha that was easy. Gotta love the forums i tell ya
Old Jun 6, 2016 | 07:30 PM
DemiBLAK's Avatar
2005 CLK500
XD this is still helping people today. I almost flipped out when my seat and steering wheel would not move. Thank good it was that simple
Old Jun 7, 2016 | 04:30 PM
Konstantin79's Avatar
Mercedes Benz CLK 270 CDI
Hi Frisco, I have no power seats, however my steering wheel is much harder to turn than the other CLK. Could it be the same issue?
Old Aug 19, 2020 | 01:09 AM
Rose Italiana's Avatar
mercedes c 250
Where is this power seat wiring located?
I’m having the same problem. My power seats and steering wheel adjuster isn’t working. I have no idea where this “magical case” is. I’m hoping it’s just a loose wire but I don’t even know where to begin. Can someone help?
What am I supposed to be doing here?
Old Aug 20, 2020 | 08:37 PM
rmetzner49's Avatar
2009 CLK350 Cabriolet with 18" AMG Fitment TSW Rims
With mine, it was a little more than the wiring harness, it was the Module itself. I have an iCar-MBII and was not able to even communicate with the module. That module runs the driver's seat, the steering wheel, and the seat belt extender.
$50 later on Ebay I was up and running again. The iCar even lets you see the motors turning via Hall Effect Sensors. The iCar-MBII was the best $150 I ever spent and it pays for itself every time something goes wrong with the electronics.
Old Jul 7, 2021 | 02:09 PM
z-wagen's Avatar
2004 E320
Hello ALL,
My W209 driver seat adjustment (forward and backward) stopped. I checked all fuses following the fuse legend and all were intact. I also checked all connection under the seat and they seem to all be intact.
The steering adjuster works as well as the seat belt extender.
This leads me to suspect that the module is the issue. Is this a simple Unplug/Plug process?
Are there other areas I should look into?
Old Aug 14, 2021 | 07:27 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
Perhaps not so astonishingly I have the same problem. Going to replace the seat switch itself although I am not optimistic. Whats weird is that my auto settings for both the seat and wheel work just fine.
Old Aug 14, 2021 | 10:37 PM
I am happy to report that the switch replacement actually solved my problem...Unfortunately it is truly a PITA job.
