will these wheels / tires fit on my W209 CLK 320
Old Jan 24, 2007 | 07:34 PM
Go Terps's Avatar
The wheels are 18 x 8.5 5-112 all around. Offset is 44mm.
The tires are 245/45R18 all around.
Will these fit at all? Using spacers or something?
I believe they are originally from an S Class.
Old Jan 24, 2007 | 07:51 PM
kaze81's Avatar
Mercedes
NO...They wont fit. The offset is too high. You can probably use spacers but I will suggest you not to, well I am not a fan of spacer though. The other problem is the tire size isnt a correct size for 18" on a CLK. Hope that helps and good luck
Old Feb 10, 2007 | 12:06 AM
kai611168's Avatar
997Turbo/S500/330Xi/ML350
I dont think it will even tho you use the spacer,because the offset for CLK is 35 max i think
