transmission problem???? or simple Tune up?
between speed 40 mile and 60 mile...
i hear noise.... feel nose under the car...
is this common problem?
is so.... what is the problem?
Is there a jolt in the transmission under acceleration like the transmission slipped?
Is the noise still present when driving in either "W" or "C" mode?
u know .... speed between 40-65 mile.....
i can explain the noise but... it is front under......i could hear and feel on my foot.....
is it easy to fix it... how much does it going to cost...
can i fix it by myself?
You will need to be more specific if you want our help. Simply saying that it's making noise doesn't help us help you identify the problem.
Like I asked before, what kind of noise is being made?
Is there a jerk or a hard shift when you're driving?
At how many RPMs does this happen?
Hand over your keys and describe the noise - refrain from guessing what the noise could be out loud. If it's a simple fix, and you told the mechanic what you thought it might be - Mass Airflow Sensor, Fuel Level Sensor, Rear Axle Bushings.. as the mechanic will also charge you to replace those, to make you feel smart, as you diagnosed the problem all by yourself.
Hand over a check or credit card.
After you heard that kind of noise, it will start slip when you kick down, it's like the you change the transmission to "N", the engine will only rev, and the car wont accelerate...
My suggest : Sell the car... I SPENT 8 MONTH until now, just trying to fix the car.
my brakes and rotors are shot but i don't think that's the problem.
lemme know.
