HELP ( back curtain problem)
Old Jun 15, 2007 | 01:49 PM
omaro's Avatar
2003 black CLK 500, 2001 dark blue ML320, 99 volvo S40 turbo, 2004 toyota prado
i own a 2003 CLK 500 and i have a problem closing the back curtain. when i press the button for the curtain to go down it does not go in properly, there is still some part of the curtain out ....any ideas how to fix this problem...thank you
Old Jun 15, 2007 | 01:57 PM
dkim's Avatar
2022 911 c4s cab, 2022 Lambo Urus
had the same problem before...it's a reoccuring issue so i just wont use the shade anymore.
Here's how i got it to go in.
Had someone in the front seat start/stop the curtain from going in little by little while i tucked the curtain in. near the bottom of the curtain, it took a few tries but finally got it to go in neatly. hope this helps.
Old Jun 16, 2007 | 07:15 PM
omaro's Avatar
i will do the same thing u did.hope it will work. but after u did that did the curtain go in and out properly after that or still the same problem??
