new wheels and tires
CLK 500, IS250 AWD
i have ordered some new work wheels for my 2003 clk 500
18 X 8.5 +30 offset 235/40/18 front
18 X 9.5 +30 offset 265/35/18 rear
The only thing is that the bigger tire size 235 versus 225 and 265 versus 255 hopefully doesn't rub or need camber adj etc.
i was going to the 235/265 setup because someone said the 8.5 and 9.5 setup might stretch the tire using 225/255 and not look good.
I don't want a stretched or tall look (225/255) but also don't want rubbing inside or on the wheel well (235/265)
any thoughts on the 235 versus 225 and 265 versus 255 tire size set up much appreciated.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
CLK 500, IS250 AWD
have you ever seen this set up for a w209 clk 500 because the 30 mm
offset pushes out the rim a bit more but it is the same setup Brabus uses
but they use a 225/255 tire combo but i think it may look stretched.
any one else with thoughts also appreciated.
thanks
thanks
