manually lowering cabriolet rollover protection
Old Jun 26, 2016 | 09:31 AM
chriscarter's Avatar
2002 CLK 320 Cabrio
Hello all - I'm a new member here and have learned a lot from all your posts. Thanks!
One clarification for this thread - The W208 bodied CLKs do not seem to have the plunger switch release mentioned above, probably because the 2 rear headrests are linked together by a heavy metal beam. In the process of repairing my stuck up rear headrests, I removed the complete assembly to figure out if they can be retracted manually. Will report back when I find out -
Old Jun 26, 2016 | 11:21 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You might get more help specific to your car in the W208 forum.
Old Jun 26, 2016 | 12:25 PM
2002 CLK 320 Cabrio
Sorry to have bothered you. I am still trying to navigate this site.
I will not post any more comments so as not to further annoy you.
Thanks again for allowing me to read others' posts.
Old Jun 26, 2016 | 12:32 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Chris, I was not admonishing you - I was just suggesting that you might get better help in the W208 forum since its roll bar and soft top system is different then the W209's. If you were asking engine or suspension questions, then I'd be able to help as those are pretty much the same.
Old Jun 26, 2016 | 08:47 PM
2002 CLK 320 Cabrio
I am now UN-registering so I can only read the threads.
Again, sorry for intruding on your forum.
Old Jun 27, 2016 | 06:36 AM
DanielFD's Avatar
2007 BMW 550i
damn it Rodney.. look what you did..
Old Jun 27, 2016 | 10:34 PM
  #32
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Gosh, I as really trying to be helpful! I do wish I knew a bit more about the W208, but I've never owned one and never worked on one. I hope Chris finds the help he/she needs and gets things working again.
Old Jul 10, 2016 | 12:40 PM
  #33
DevlZT's Avatar
2003 Mercedes CLK 430 Cabriolet
Is a 2003 any different than the rest?
I have a 2003 and Im just not finding this little switch you speak of... I've watched a million videos a million times. Ive stuck everything down the side of that headreast from coathangers, allen wernches...goat horns... Somebody PLEASE send me a pic of your finger pointing where I should be looking on my 2003 clk430!
Old Jul 10, 2016 | 05:06 PM
  #34
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MY2003 cabriolet isn't a W209 - it's a W208 and the roll bar system is different.
Old Aug 13, 2016 | 06:22 PM
  #35
CLK280_AUS's Avatar
2005 CLK240 Convertible Elegance Black
Thisvideo was the best i have seen. Solved the problem for me
Old Aug 13, 2016 | 11:19 PM
  #36
DevlZT's Avatar
So is mine.
Old Aug 14, 2016 | 11:21 AM
  #37
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
"MY2003" = Model Year 2003, not "my 2003". You have a W208, not a W209. The guys in the W208 forum might be of better help"
https://mbworld.org/forums/clk-class-w208-5/
In fact, a quick search there for "roll bar" yielded this post:
https://mbworld.org/forums/clk-class...ering-how.html
Old Jun 18, 2017 | 01:11 PM
  #38
clydem's Avatar
2005 320CLK Cab
2005 CLK convertible: Just wanted to dig this up again as I got into the wife's car & the rear view mirror was kinda blocked. I asked her, "OK, what did you hit?"
and of course, got the "Nothing! I noticed that a few months ago." me: "not quite. I just washed & vacuumed the car less than 2 weeks ago" her: "It must have been 2 weeks then"
Uh huh. This time I noticed I could move the one headrest to the left enough to peer in & see the trip-lever. More towards the front of the headrest than the back. I used a long flat blade screwdriver. Phillips works too. As noted, the first lever is a stinker to find. the next is much quicker. There is a youtube video though the mook blocks the view when he tries to muscle the headrest down.
And, we are back in business with a functioning convertible.
Originally Posted by alfswan
This solution worked for me and its very simple using a suitable tool.
http://mercedesforum.com/forum/showthread.php?t=29336
Old Dec 17, 2017 | 01:14 PM
  #39
holdencawffle's Avatar
CLK320
Originally Posted by Najwan
Once i asked the dealer to teach me how to fix this problem my self he replied that the emergency bridge locks and i need a specific tools to unlock it besides he said it will take around 2 hours of working, i think if the process were to easy they will submitted the solution in the manual, but its really annoying.
Yeah, I think your dealer is a crook
Old Apr 13, 2023 | 11:56 AM
  #40
vandnbg's Avatar
CLK 350
Pushing the Head rests down is very hard
Originally Posted by Louie D
Your RIGHT ! Its very hard had to get a second person for me.
If you are right-handed you will be holding the release spring down with your dominate hand and trying to force the very heavily spring-loaded head rest down with your non-dominate arm in a very cramped space where you can get no leverage. I couldn't do it. I attached a vice grips to the rod I was using to hold the spring down and was able to wedge it against the top and hold the release spring down and freeing my right arm. I was then able to wrestle the head rest down using both arms.
