Smartkey
Old Feb 6, 2008 | 10:17 AM
rparrish22's Avatar
2003 Clk 500
Smartkey
I see these smartkeys for sale on ebay and I was wondering how do I program on to work with my 03 CLK500. My key is getting worn out so I would like to replace it. These are much less expensive than the dealers so any help would be appreciated.
Old Feb 6, 2008 | 10:31 AM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
yah, i saw those aswell...for roughly 35 bux a pop im kinda scared about using them...my key is also taking a beating and its my only one.
i would assume that you must go to MB to get the key programmed?
Old Feb 6, 2008 | 12:30 PM
rparrish22's Avatar
2003 Clk 500
I googled it and it says put it in the ignition and press certain buttons and it takes up to two hours to program. But this was for a 1998. I am not certain if it will work on a newer version.
Old Feb 6, 2008 | 01:00 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Sorry x2. STFF as this has been discussed numerous times.
Old Feb 6, 2008 | 03:40 PM
rparrish22's Avatar
2003 Clk 500
I appreciate your prompt response to send us through the forums looking to see if there was an answer to my question. But unfortunately I must not have STFF very well because there is still not an answer to my question. I am asking how to program a smartkey for a w209(not w208) 2003 CLK500. Can I program it or must it be done by a dealer.
Searching (again) through the forums before I wrote this post did let me see something else that seemed like a nice addition. One of the posts shows someone with a W208 ordered the new chrome key. Has anyone tried this for a W209 and got it to work?
Old Feb 6, 2008 | 03:45 PM
M-bENZ's Avatar
Corrolla
rparrish22,
To be honest with you IDK how to make it work but I was just got it from a dealer for $200 even
Old Feb 6, 2008 | 09:20 PM
carson357's Avatar
2005 C-230 Sport Sedan
honestly, they are only good for parts, they can never be reprogrammed by conventional means, i have a factory mercedes diagnostic system and am still unable to, i am sure the department at mercedes that makes them could, but i am also sure they would rather sell you a new one, unless your key is phsically damaged externally dont waste your money, they can be opened and the internals changed to another good housing
Old Feb 6, 2008 | 10:00 PM
User110's Avatar
2003 Cl 500
think its possible to take a new key apart and put the old key inside of it?
maybe?
ALi
Old Feb 6, 2008 | 10:47 PM
iguess's Avatar
2006 CLK350
if i remember correctly, you cant do it yourself. you have two options. get a new key from the dealership or get it from oemparts. they somehow program it if you give them your VIN . (if you search chrome key, you should find some posts)
Old Feb 7, 2008 | 01:06 AM
MiamiMerc's Avatar
2007 CLK 500
maybe?
ALi
No the dimensions are different.
Old Feb 7, 2008 | 02:08 AM
carson357's Avatar
maybe?
ALi
it is possible, the only variable is the donor has to be physically the same type key
Old Feb 8, 2008 | 10:29 PM
stormkenny3's Avatar
clk 500 2003
all i can say is, i think u need to take it too a dealer to get programmed.
