To Straighten a Wheel?
I am going to a tire store next week to check if the one or both the front wheels are bent. If so, they will send it out for repair.
The cost is about $100 per wheel. Does anyone know how do they straighten a wheel?
Do this test. Find a flat surface and go really slow, walking speed... Get your hands off the steering wheel and observe any steering wheel motion to left of right. If you see any movement that repeats itself approximately in same distance every time you most likely have tire wall damage. My car has 19" 35 series on front and I have this problem.
Here is another problem that happens quite often. Tires slip on the wheels. When you get your tires balanced, take a paint marker and mark the tire / wheel location on the in side. Sometimes when you get brand new tires mounted they use excessive amount of lubricant to get the tires on. When you brake hard tires can slip on the wheels causing them to be off balance. Take it easy for several days and let the lube completely dry out.
Hope that helps,
Juha
Wheel straightening works great. I've had 3 wheels done there. The wheels come out incredibly true, and there are no noticeable marks on the wheels, so you can't tell where they worked on the wheels.
There is no heating, or if there is, it's at least not enough to destroy the existing paint. They won't repaint it unless you pay them too, but I did have them refinish one of them, and while the wheel looked fantastic, it was shinier than the other 3, and did not match.
This place, and others like it, do wheel straightening all day long. It is no big deal.
I checked www.rimpro.com and it said it was a proprietary process, so, no detail there. If they heat it up, it may damage the finish. If they hammer it, it will definitely noticeable. If you said it is not noticeable, how do they do it?
These guys give lots of detail on their process. It uses mild heating to solften the metal, but that's it.
I'm not an expert on the process...
neways they did a nice job...!!!
as it will show up when they spin it on the machine
Several other items to look at..out of round tire..worn suspension/shocks
There are compositions that are not typically brittle (pure aluminum plus vanadium I believe), and processes such as annealing you can do to cast metals like aluminum not brittle.
