Problem With 1999 CLK320, It Thinks It's Running Out Of Gas When It's Not...
etc etc etc .. hard to diagnosis over cyberspace!
Good Luck
Could be just turning off the engine and let it cool for a few minutes, it will start right back up; which means an intermittent electrical problem... so Marcus theory of the bad CPS is a good one.
On the other hand, when did you last change the fuel filter?
What is the mileage on the car?
When the engine fails again, can you listen and hear (under car, near right rear wheel) the fuel pump working? If not, you should swap the fuel pump relay; and if you still can't hear it, then it's a bad fuel pump.
Worst case when it fails again, call MBZ Roadside Assistance and let the Knight in Shining Armor diagnose the problem for you on the spot !!!
