New tires rated 94w instead of 91w
Old Sep 30, 2008 | 07:41 PM
Tdog1's Avatar
2012 GL550, 2006 CLK350, 1999 Porsche 911
I just put new tires on my '06 CLK350 and I didn't realize until too late that the fronts indicate they are 94w instead of the factory 91w which means (I think) that they have a stiffer sidewall than the 91w tire. Anybody know if there is any reason I shouldn't use these tires? Thanks. BTW, the rears are 91w.
Old Oct 2, 2008 | 07:09 PM
moondust's Avatar
2004 CLK 240
From what I understand (and I'm not a tire expert!) your 94W are OK, but were not required for your car, and probably cost you a few dollars more than the correct 91W.
They are designed for "MPV's, Light Commercials or Large Saloons, are also used for low profile tyres where extra sidewall strength is required"
Old Oct 7, 2008 | 01:28 AM
DougCLK320's Avatar
CLK320 Cabriolet (A209)
As Moondust says, these are for a heavier car. You may find the ride quality and tyre noise slightly worse.
Old Oct 8, 2008 | 10:19 PM
Tdog1's Avatar
After a week on the new 94w tires I have to say that I don't notice anything different in ride or handling. There is an ever so slight pull to the right even after a 4 wheel alignment. The mechanic thinks it could be from a radial pull in the right front tire. I'm debating whether to have the tire replaced or wait and see if it goes away.
Old Sep 8, 2011 | 03:46 PM
SGM's Avatar
SGM
2007 SLK350
I have 94w on the front and 91w on the rear of my SLK350 and have no problems at all.
Old Sep 8, 2011 | 04:06 PM
SGM's Avatar
SGM
2007 SLK350
P.S - I'm very new to this site and am looking forward to joining in other topics. It looks like a good place to be
