Intake hoses
Old Feb 11, 2009 | 09:46 PM
advans's Avatar
C55 ///AMG, 535xi
Intake hoses
Hey guys,
I was wondering if anyone has the CLK350/550 kevlar intake tubes lying around? If anyone does, lemme know. I need a set.
Old Feb 12, 2009 | 10:50 AM
advans's Avatar
C55 ///AMG, 535xi
anyone??
Old Feb 12, 2009 | 12:21 PM
ZEEK's Avatar
Yo Momma
what are you looking to do dude? did you try ebay?
Old Feb 12, 2009 | 12:27 PM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
theres a company here in vancouver that makes carbon/kevlar tubing for about 5-6 dollars an INCH...
http://www.geminicomposites.com/prod...ber_tubes.html
Old Feb 12, 2009 | 03:32 PM
advans's Avatar
C55 ///AMG, 535xi
I'm trying to fit the new carbon kevlar tubes into the C55, I did a test, and fit the C350 tubes on my C320, and it made a huge difference after the engine gets hot. Because once the engine gets hot, the tubes get hot, and the air that come in gets warm instead of being cold.
Since the C55 tubes are "curved" in a way, those carbon kevlar tubes wont work, unless its the stock CLK350 or CLK550 tubes.
anyone with a CLK350 or 550 can chime in, take a picture of your engine bay with the tubes??
Old Feb 12, 2009 | 03:36 PM
ZEEK's Avatar
Yo Momma
hmmmm interesting...
Old Feb 12, 2009 | 04:36 PM
M-bENZ's Avatar
Corrolla
if u do it too ...let me know I might do it
Old Feb 13, 2009 | 01:01 AM
advans's Avatar
C55 ///AMG, 535xi
those carbon kevlar tubes are better than the stock plastic ones. I've been there.
I just need someone with a CLK350/550 to take a picture of the engine bay and the tube shape.
Old Feb 13, 2009 | 01:07 AM
ZEEK's Avatar
Yo Momma
i think klinh has the 550?
Old Feb 13, 2009 | 11:38 AM
M-bENZ's Avatar
Corrolla
clk 350-07,
http://i230.photobucket.com/albums/e.../clk350-07.jpg
Old Feb 13, 2009 | 01:08 PM
buffyclk500's Avatar
clk500
juat so u no they r 120 a set a the benz store
Old Feb 13, 2009 | 02:32 PM
advans's Avatar
C55 ///AMG, 535xi
wow, $120 a set. hmm... I'm not 100% sure if this would work, thats why i'm looking for a used set
Old Feb 13, 2009 | 08:56 PM
omar26's Avatar
E55
would those tubes fit on a 500 engine?
Old Feb 13, 2009 | 11:07 PM
M-bENZ's Avatar
Corrolla
What tube??? the one in carbon fiber from the site ???
Old Feb 14, 2009 | 01:32 AM
omar26's Avatar
E55
the ones off a 350 or 550
Old Feb 14, 2009 | 10:26 AM
advans's Avatar
C55 ///AMG, 535xi
it might/might not fit, thats why I want to do a test first.
the tubes on the 500 is pretty much the same as the 55 ones, well, close enough, everything pretty much falls within the same areas, so fitment is probably possible.
Old Feb 14, 2009 | 12:03 PM
clk500
i looked in 2 it and they will work with some mods
Old Feb 14, 2009 | 01:39 PM
advans's Avatar
C55 ///AMG, 535xi
yeah tahts good, try it out! it's def a worth while upgrade (especially for hot summer days)
Old Feb 14, 2009 | 03:52 PM
omar26's Avatar
E55
ima order mines on monday along with the e55 kompressor intake
Old Feb 14, 2009 | 09:51 PM
clk500
show pics when done
Old Feb 15, 2009 | 11:49 AM
advans's Avatar
C55 ///AMG, 535xi
I would double check the e55 intake hoses. When i had the C32 intake on my 320, the intake hoses were different.
Old Feb 15, 2009 | 02:14 PM
omar26's Avatar
E55
yea ill check them out n let every1 know, is the e55 kompressor box direct fit?
Old Feb 15, 2009 | 07:00 PM
advans's Avatar
C55 ///AMG, 535xi
it is a direct fit for a C55 amg, one thing, if you buy the Y-section, you'll need modification for it to stay on the MAF.
Old Feb 15, 2009 | 11:40 PM
omar26's Avatar
E55
wouldnt it be necessary for me to purchase the y pipe? n wot kind of modification
Old Feb 16, 2009 | 08:07 AM
advans's Avatar
C55 ///AMG, 535xi
yes you do!
if you want the E55k setup, you'll need...
1. R+L Air Cleaner (airboxes)
2. Y-Section+tubes+bracket
3. Airbox brakets
4. Filter assembly
(I think you might be able to use the stock tubes, or the kevlar tubes).
The whole set-up runs for about $300 ish dollars +/-
As for the Y section modification, you'll need to "cut off" this tab that prevents the Y section to sit on your MAF (its straight forward, you'll know wth i'm talking about once you have the Y-section). Then you'll need a silicone coupler and brackets to "tie" the Y section onto your MAF.
