Clicking noise?
2008 E550 4matic, 2004 CLK500
Clicking noise?
After I start the car I hear a clicking noise. Sounds like it comes from the area around the key. After driving for a while, it goes away. Any thoughts?
1 Post
I drive the racism out of BadDebt. ;)
if it is inside your cabin, and the clicking begins at startup for about 30secs and then goes away...its certain that it is your step motor which controls your climate control flaps....
A clicking noise is the result of a broken swing arm that is attached to your step motor...it clicks everytime it does a 360* rotation...
The remedy for this would to pull your dash, find the correct step motor that has failed and DIY the rotating lever.
1 Post
its not that hard if you do it yourself...get yourself a torx driver set and get out the T-20 and go to town under the drivers dash...its about a 2hr job if you're mechanically inclined. The shop will charge you more than 1200 bucks. The part is 150 bucks, the labour is 900 or so.
I'm not mechanically inclined so I would have to bring it to the shop. $1200 sounds pretty steep. Is there any risk of further damage if I dont get it fixed right away? Will this affect the performance of the heat/AC?
2003 CLK500
Fortunately, the clicking went away after a while, and everything still works perfectly!
Good luck to you, bro!
i have a ticking noise on my 08 and it can only be heard inside
but it happens almost all the time, not only when I first turn it on
but my heat/air is always off
anyone know what it could be?
CLK 500 W209
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Vishal
