Power Steering Fluid Type
Old Apr 8, 2009 | 06:14 PM
MB_E430's Avatar
2007 C230 Sport
Are there any specifications for the type of power steering fluid used in a 2005 CLK 320?
Old Sep 25, 2009 | 09:30 AM
dandadda's Avatar
clk 500
Anyone have a clue on to what power steering fluid to use in the clk500? will the mobil 1 synthetic ATF work ok? anyhelp will be appreciated!
Old Nov 2, 2017 | 03:07 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
I think there is a lot of confusion. MB and Chrysler developed ATF+4, and used it as PSF, as far as I know. That means any good ATF will substitute. BUT mixing ATF with Pentosin means disaster, they are the one truly incompatible fluid combo in auto industry.
Best method is to smell or inspect the current fluid. Red and smelly = ATF
Old Nov 2, 2017 | 03:27 PM
This clears it up:
See how the approved fluids are labeled ATF...
I'm re-verifying this in my W209, but stumbled on this post.
https://bevo.mercedes-benz.com/bevol...griff=steering
236.3 Steering gear oils (ATF, Specification 236.3)
The following product list should help you to select the correct operating fluid for your vehicle/major assembly from the variety of products in the market.
We are recommending to use exclusively the products listed in the following overview, because only these products have been tested and approved by Mercedes-Benz.
We recommend using only products
  1. which are distinctly marked with the label indicating the approval of Mercedes-Benz, e.g. “MB-Approval 229.51”. Labels referring e.g. to “MB 229.51” don't have an approval of Mercedes-Benz.
  2. Which are listed in the current MB BeVo. Only listed products are tested and approved by Mercedes-Benz.
Application in vehicles/major assemblies refer to Sheet 231.1 (passenger cars, cross-country vehicles) Sheet 231.2 (commercial vehicles) Sheet 231.3 (UNIMOG, MB tractor)
Select Sheet 023.0110.1111.0112.0119.0121.0125.0127.0131.0132.0 134.0135.0136.0137.0138.0138.1141.0210.0211.0215.0 219.0221.0222.0224.1224.2226.5226.51228.0228.1228. 2228.3228.31228.5228.51228.61229.1229.3229.31229.5 229.51229.52229.6229.71231.0231.2231.3235.0235.123 5.10235.11235.12235.13235.15235.16235.20235.27235. 28235.29235.3235.31235.4235.41235.5235.6235.61235. 62235.7235.71235.72235.73235.74235.8236.1236.10236 .11236.12236.13236.14236.15236.17236.2236.20236.21 236.24236.25236.26236.3236.41236.6236.7236.8236.81 236.9236.91238.22239.71239.72261.0264.0265.1266.02 66.2267.0267.1269.2312.0325.0325.3325.5325.6326.03 26.3326.5326.6330.1331.0331.1332.0340.1341.0342.03 43.0344.0345.0346.0350.0361.0361.1361.3362.0362.13 62.2362.3363.0371.0381.0382.0383.0385.1385.2385.33 85.4385.5 Overview
Search ResultsLast update: 11/02/2017ProductnamePrincipalProductnamePrincipalMB 236.3 Servolenkungsöl A 000 989 88 03Daimler AG, Stuttgart/DeutschlandFuchs PENTOSIN PSFFuchs Petrolub AG, Mannheim/DeutschlandGONHER ATF DIID M 6.3Lubricantes de América, S.A. de C.V., SANTA CATARINA/MEXICOGulf ATF MXGulf Oil International, London/ENGLANDLIQUI MOLY LENKGETRIEBE- ÖL 3100Liqui Moly GmbH, Ulm/DeutschlandLUBRAL ATF DIID M 6.3Lubricantes de América, S.A. de C.V., SANTA CATARINA/MEXICOmegol Lenkgetriebeoel StabilityMeguin GmbH & Co. KG Mineraloelwerke, Saarlouis/DeutschlandPANOLIN ATF MULTIPANOLIN AG, MADETSWIL/SchweizPETRONAS ATF FLUID 236.3PETRONAS LUBRICANTS INTERNATIONAL, VILLASTELLONE (Torino)/ITALYSinopec Greatwall ATF-B3
Old Oct 22, 2018 | 01:07 AM
It looks like CHF 11S or similar "synthetic" PSF is required. My 2007 had ATF in the reservior, so kind of confusing. I have to flush it back to CHF 11S, and do it completely as the fluids are not compatible. Not "miscible", they don't dissolve in each other and cause poor lube conditions. It will kill the system.
Old Apr 23, 2021 | 02:45 AM
My 2006 CLK is fine on ATF.
This is what I'm trying now...
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
236.3 is a Dex ll product...
Old Sep 7, 2021 | 12:12 PM
JonMBZ's Avatar
06 C55, 09 E350
You should be using 345.0
