LED DIY
Old May 23, 2009 | 01:44 PM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
LED DIY
Ok, I want to change most of my bulbs to LEDs
I want to double check with you guys if I have all the
RIGHT LED models before buying
Here we go
1-Parking light: 194
2-Tail light: 7225
3-Stop light: 1156
4-Licence plate: Festoon ? 36 or 39mm ? Resistor ? how many?
5-Back up light: 1156
6-Front sidemarker: 194
7-Glove box: Festoon ? 36 or 39mm ? Resistor ? how many?
8-Map light: ?????
9-Dome light: Festoon ? 36 or 39mm ? Resistor ? how many?
10-Step/courtesy light (in the door): Festoon ? 36 or 39mm ? Resistor ? how many?
11-In the trunk area: Festoon ? 36 or 39mm ? Resistor ? how many?
Resistor needed : #4 (2) I think... anyone confirms?
I did not include Turn LED (I think it's a little ricer...) BTW you need resistors
OK soo do anyone know anwers to 4-7-9-10-11?
Web sites:
www.autolumination.com
www.superbrightled.com
www.v-leds.com
www.advancedautomotiveconcepts.com
Let's complete the liste
Tony
Old May 23, 2009 | 07:24 PM
M-bENZ's Avatar
Corrolla
For the city light I think you should have 194 but anyway for the LED check the section W204 there is a groupbuy for those LED (w/out any error or resistors).
Lisence Plate : check my thread out "Got my LED installed" from W209 section see if you like then I let you know the detail and thats all I can answer.
and here is the list of bulbs,
2005 MERCEDES-BENZ CLK (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
H7
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7EB EcoBright - Your Environmental Choice
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
Parking light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
2357A
2357ALL Long Life Upgrade: Up to twice the life of the standard lamp
2827
Rear turn signal
7506
7506ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7225
7225LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7506
High mount stop light
Assembly
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
License plate
6418
6418LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7506
Front sidemarker
2825
Rear sidemarker
2825
Glove box
6418
Map light
2886X
Dome light
6411
Step/Courtesy light
6418
Trunk/Cargo area
6411
Andy
Old May 24, 2009 | 04:25 PM
FatTony001's Avatar
Thanks Andy for putting that list up
I had that list from Sylvania at home... some of the numbers on that liste
is not applicable when you buy LED or bulb from eg:autolumination
That's why I posted my list
Wanna complete my list with me?
#4 Licence plate light... Did you use 36mm Festoon or 39mm ?
and I think you needed a resistor too right?
Soo I would need 2 Festoons et 2 resistors (or load equalizer) of 15-25 Ohm Right?
Old May 25, 2009 | 12:41 AM
M-bENZ's Avatar
Corrolla
hey you welcome...Anyway, for the dome light I couldnt remember that I use 36mm or 39mm but I think you can fit both in (front and back are the same).
Here is the Cross Reference (Festoon 31mm,36mm,39mm,41mm):
212, 211, 212-2, 214-2, 3423, 3425, 3022, 3021, 3175, 6411, 6413, 6418, 6423, 6428, 6429, 6430.
#4 License Plate Light: I used two 36mm festoons with two resistors(one for each side). Did u see my thread yet ? If u really want to do that pm me your email I'll send you some pics with the detail how to connect those.
Andy
Old May 25, 2009 | 02:00 PM
FatTony001's Avatar
Update
2-Tail light: 7225
3-Stop light: 1156
4-Licence plate: 2 Festoon 36mm need 2 Resistor 15-25 Ohm
7-Glove box: Festoon 36mm
8-Map light: ?????
10-Step/courtesy light (in the door): Festoon 36mm
Resistor needed : #4 (2 resistor) 15-25 Ohm
Old May 26, 2009 | 03:09 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
I tried several led's and resistors for the front parking lamp, but could not get it to work - either still blinking or not lighting up at all. If you guys have done this or figure it out please post resistor and or wiring. Thanks!
Old May 26, 2009 | 06:48 PM
M-bENZ's Avatar
Corrolla
be patient let me test these bulbs from the Group Buy (W204 Section) I just got it today and will update later. Here is the pic. of the bulb,
Andy
Old Jun 15, 2009 | 07:07 PM
njzprettyboy's Avatar
R8 V10
do your resistors get super hot? if so, where did you guys mount them? I am getting an error on my left bulb, not the right though. I installed a 6ohm 50 watt resistor and it melted right through my trunklid....my car smells like burnt plastic :-(
Maybe the 15-25 doesnt get as hot?
Old Jun 15, 2009 | 09:48 PM
M-bENZ's Avatar
Corrolla
use 5W 250 ohm...no complaint so far.
Andy
Old Jun 15, 2009 | 11:02 PM
R8 V10
where did you mount em? do they get hot? got a link to it?
Old Jun 16, 2009 | 12:54 AM
ZEEK's Avatar
Yo Momma
all resistors will get hot, i had all white leds on my w208. To prevent resistors getting very hot and touching other things by the engine i wrapped the resistors in black electrical tape.
Old Jun 16, 2009 | 01:07 AM
M-bENZ's Avatar
Corrolla
This is where I mounted those resistors...again, you can mount those wherever you want as long as they against metal not plastic. For some reason, my resistors not that hot at all I would say they are warm. Pm me if u have any questions.
Andy
Old Jun 16, 2009 | 07:34 AM
R8 V10
^^whered you get that specific ohm/wattage? radio shack?
Old Jun 16, 2009 | 11:29 AM
M-bENZ's Avatar
Corrolla
I'll get u back on this tonite cause im in my office right now cant remember the link.
Andy
Old Jun 27, 2009 | 12:26 AM
Jason1000RR's Avatar
women crazy.
Has anyone done a complete interior LED conversion using materials from SuperBrightLEDS.com?
http://superbrightleds.com/led_prods.htm
Old Jun 28, 2009 | 12:18 PM
women crazy.
Andy
Did you get a chance to install these yet?
Old Jun 28, 2009 | 09:46 PM
lowpost's Avatar
I got those - works fine. I got the license bulbs with the built in resistors from ebay too - works good. Why do so much work?
Old Jun 29, 2009 | 12:07 AM
women crazy.
****, can't find "Blesk LED's" on eBay anymore...I totally agree, I don't wanna mess with resistors and such. So I'm looking for an integrated solution.
Old Jun 29, 2009 | 01:12 AM
bheng's Avatar
2003 CLK 320
http://cgi.ebay.com/ebaymotors/White...Q5fAccessories
are these the ones you were looking for? I think they are the same size. I am looking to get these on my next paycheck haha
Old Jun 29, 2009 | 02:30 AM
women crazy.
bheng, excellent find. Thank ya!
Old Jun 29, 2009 | 02:58 AM
bheng's Avatar
2003 CLK 320
yeah no problem man. welcome to the forums btw.
Let me know how the lights work and stuff. I will probably get them in like a couple of weeks from now. But they seem to have a good guarantee.
oh and btw.
hows the 1000rr =P?
Old Jun 29, 2009 | 03:04 AM
women crazy.
The CBR1000RR is a monster. A dependable one too...
Old Sep 17, 2009 | 01:24 PM
anthonyy's Avatar
2006 C280
sorry if this is in the wrong post. I installed leds on my friend's parking lamps and side markers on his '06 clk 500. Everything works great, but errors come up on dash. Any help?
Old Sep 17, 2009 | 01:36 PM
M-bENZ's Avatar
Corrolla
what kind of LED did you installed ? Did you get from the GB(groupbuy) ?
Andy
Old Sep 17, 2009 | 02:31 PM
azndaivd85's Avatar
CLK 320
Anyone know how to remove the plastic map light cover??
