no sound from speakers
Old Apr 3, 2013 | 09:01 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Pull the fiber optic cable from the amp (in the trunk, behind the carpet, right fender) and check for light. You'll see it if it's working. If not, then the fiber cable is broken or unplugged somewhere along it's continuous "ring".
SAFETY EDIT: Don't look directly at the end of the fiber cable - point it at a white piece of paper or just look at it from the side in the dark.
Old Apr 4, 2013 | 01:11 PM
JDCLK5's Avatar
clk 500 2006
Okay so im going to check it this afternoon. So the light should be comming from the fiber optic cable itself? And i know there was forsure a red light on inside the amp when i looked last night does that have a meaning? And the amp im guessing is the larger of the two rectangular boxes in the rear passenger side trunk space.
Old Apr 5, 2013 | 09:18 PM
JDCLK5's Avatar
clk 500 2006
the red light is on constanly with stereo on. then i just had an idea to unplugged cd changer fuse then the red light blinked and kept blinking till i put it back in then still constantly red, i'm thinking a broken spot in the loop or bad changer. any ideas??
Old Apr 6, 2013 | 01:33 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Unplug the fiber optic cable (the stiff orange wiring, always in a pair). On the end of the connector, there will be two lenses - one white one red. You should be able to see light in one of them. If not, then there is a break somewhere in the fiber ring.
Old Apr 7, 2013 | 08:23 AM
JDCLK5's Avatar
clk 500 2006
Okay i took it to a family members garage, has the best scanner around. U1000 code came up with a short in the circuit. But wasnt able to tell me anymore. Any ideas what part could be throwing off the system.?
Old Apr 7, 2013 | 12:13 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'm not sure what "U1000" is. I can't find that in any of my documentation. The native codes for the sound system look more like this:
http://benzbits.com/SOUNDcodes.pdf
I am not aware of any non-MBZ scanners that will read these codes.
Old Oct 28, 2014 | 02:50 AM
  #32
E46zhp's Avatar
2005 bmw 330ci zhp
i unplugged the fiber optic cables from the amplifier and turn on my radio and i had the Amp blinking once but nothing from the fiber optic cables....? then i did the same with CD changer, the CD changer and fiber optic cables both blink twice!.. then i put a flash light on the fiber optic cable end and i could see the light coming thru the fiber optic cable at the AMP and the CDC...
i have the same problem as stated before
"its weird the radio is on, no sound is coming out, when i hit cd, it says no cd changer when there is one in the glove compartment"
Old Feb 7, 2015 | 10:20 PM
  #33
mjaccim's Avatar
SL500
2008 CLK 350 Radio no sound fuse
I had same issue pulled the "sound system" fuse #26 and replaced and sound came back on...
Hope this helps...
MJACCIM
Originally Posted by hawee
Hi
I have a 03 clk500 and just the other day while i was driving the sound from my speakers just went away. The radio seems to be working fine but there isn't any sound. I've read on here to check the fuse, but i don't know where to find the fuse for the speaker if anyone could direct me. Also after my sound went out, when i hit cd changer it tells me theres is no cd changer.
Any ideas?
Old Feb 9, 2015 | 08:59 PM
  #34
TheNoble's Avatar
2003 CLK320
When you try to eject the cartridge does it come out or does the eject button just blink green?
Old Feb 10, 2015 | 04:08 AM
  #35
DanielFD's Avatar
2007 BMW 550i
ok I have of experience with this, hopefully it can be of some help. The D2B system works in a curious way. there's the fiber optic ring and then there's the D2B wakeup signal that runs through the cars wiring. basically the D2B wakeup signal sends a signal for the component that needs to be turned on, be it that amp or CD changer, then that component turns on to accept the light passing through the fiber optic cable that in turn passes on the signal and so "the D2B ring". When I retrofitted command 2.0 I faced an annoying problem. I plugged in everything but go no sound from the speakers. I tried restarting the optical ring through star and still got nothing as if the amp and cd changer wasn't installed. at first I thought my connections weren't tight or my D2B wakeup signal wire wasn't passing enough current. I eventually unplugged all the fiber optic cables and tried cleaning them, nothing would work. Even on STAR I couldn't get the command to see my amp and CD changer. Eventually I noticed that I was getting that one blink from the fiber optic wire then it wouldn't turn on anymore. On my last try I unknowingly plugged in the D2B connector into the headunit before plugging in the power connector (B connector, if i'm not mistaken). somehow everything worked.. I then opened STAR and configured everything. I'm guessing when the power is first given to the headunit it will conduct a small search through the ring to tell if it has anything plugged in, if it finds nothing then it shuts it down. I think while having everything plugged in pulling the fuse and putting it in will probably solve your problem. If that doesn't work then you need STAR to reconfigure the D2B network. (D2B is very unstable, that's why it was changed to MOST, it is possible your headunit forgot its configuration)
Old Feb 10, 2015 | 02:11 PM
  #36
DanielFD's Avatar
2007 BMW 550i
Also as a side note, i also had a similar problem in my c class. Whenever i went into a pothole i would loose sound. And then id find another pothole to hit to get the sound back. Try explaining that to an audio specialist.. Eventually i found out where the amp was and pulled it out and it was fully packed with dust. It seems insulation backing peeled back on the inside of the sheet metal and desingrated into dust and filled up the d2b connector on the amp; hence the potholes' effect on my audio system.
Old Mar 2, 2016 | 11:51 PM
  #37
DRACO's Avatar
85 911 Targa
Bringing back an oldie but goodie :-)
So wife's Cabrio sound no more but radio turns on and aux for ipod was displaying on the gauge but no giggity giggity.
Removed and Replaced fuse 26, No Joy ( Left Side Dash )
Removed and Replaced fuse 64, No Joy ( Engine Compartment Driver Side )
Removed and Replaced fuse 20, No Joy ( Trunk Driver Side )
Thought about it for awhile then deduced the 11+ year old fuses may have too much resistance? In any case, I decided to put emory clothe to all of them.
Removed them all at the same time and polished with emory clothe, to insure Radio is in fact dead, I turned the car to acc. Gauge Display shows: "Radio ---" = DEAD.
Placed 64 first, 26 second then 20 last.
Wait for it..........................
Turned key to acc, We have SOUND :-) giggity giggity :-)
I wonder how long it will last but, if I have to do this twice a year, I can live with that or save up to change the entire system out for a bluetooth ready with navi unit. Who listens to CDs anymore, right?
Jim
Old Mar 3, 2016 | 07:25 PM
  #38
DRACO's Avatar
85 911 Targa
So far so good, wrench noted a stored fault code that the Head Unit may be faulty.
Well good excuse to get a new Head Unit with Navi and Bluetooth or even touch screen :-)
Old Mar 8, 2016 | 01:32 PM
  #39
DRACO's Avatar
85 911 Targa
Update, A week later, Sound is still good.
So wrench tells me Fuse 26, is the the hard reboot.
Old Jun 13, 2016 | 03:40 PM
  #40
m1mmmm's Avatar
2006 CLK350 Cabriolet (A209)
Thanks Draco! Discovered speakers dead today and checked fuse 20 in trunk and noticed fuse prongs were grayish and after cleaning replaced fuse and have sound again. I have had my car since new and am thinking it would probably be a good idea to replace all these fuses since I'm sure they are all in the same condition. Thanks again for the tip!
Old Jun 13, 2016 | 03:48 PM
  #41
DRACO's Avatar
85 911 Targa
Cool, no need to replace, just remove and polish, corrosion creates too much resistance and cause havoc for the Sound System ECU due to drop in signal as the fuse is the weak point.
Old Jun 13, 2016 | 04:17 PM
  #42
m1mmmm's Avatar
Did you clean all your fuses? My car is going to be a keeper "weekend car" and has been exposed to high Texas temperatures since new so I want to eliminate as many future issues as possible. I was surprised at the amount of corrosion that had built up and I'm sure this was the first time that fuse had ever been out. Thanks, Mike.
Old Jun 13, 2016 | 04:22 PM
  #43
DRACO's Avatar
85 911 Targa
Yes, all my sound system components with emory cloth. I think there were like 3-4 fuses???
Old Jun 13, 2016 | 04:37 PM
  #44
m1mmmm's Avatar
But what about the rest of the fuses for the car? Wouldn't all our 10 year-old fuses have the same amount of corrosion? Or am I missing something? I guess I'm assuming if one fuse looked like that they all do. I'm not educated in electrical issues at all, just thinking about it in a practical manner.
Old Jun 13, 2016 | 04:39 PM
  #45
DRACO's Avatar
85 911 Targa
You have a good point. It would not hurt to check all the fuses.
On my 30+ yo 911 I replaced them all since they were all original :-o
Old Feb 7, 2019 | 08:28 PM
  #46
Gultekin Gulsen's Avatar
CLK 350
And fuse 36 too!
I took out and placed 64, 26, and 20 back in that order but it didn't work for me. Then I took 36 out (7.5 A ) and placed it back. And it worked!!
P.S. every time I took the fuses out, I turned the radio on without the fuses, turned it off, and placed the fuses and turned the radio on again.
Old Feb 7, 2019 | 10:22 PM
  #47
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Fuse 36 is for the AGW (audio gateway) module. Definitely should be one to check with audio issues.
Old Apr 17, 2023 | 11:37 AM
  #48
TBlas's Avatar
CLK350
Fix I discovered for No Sound from Speakers
Hi
Any ideas?
Here are my notes from my 2006 CLK350 convertible (W209) that was having the same issue:
4/17/2023
Issue: No Sound coming from speakers in FM mode or CD's.... all CD units stating No CD(s) in main unit or glove box CD Changer...yet there were CD's in all of them.
Pressing & Holding the "Eject CD" button for 10+ seconds didn't (initially) fix it during 1/2 hour ride home. Everything had been working fine on way to previous destination.
Tried turning car off, waiting 30+ seconds, then restarting....still not kicking audio back on : (
Fix: Waited til next morning. Still same issue as above. However, after pressing and holding the "Eject CD" button for 10+ seconds, it finally recognized and started playing CD after re-inserting it. FM radio started working again too : ) I guess some overnight patience paid off : ) : )
Old Mar 22, 2024 | 09:58 AM
  #49
mcraec620@gmail's Avatar
2005 Mercedes Benz CLK320 convertible
Mercedes-Benz CLK 320 convertible
Originally Posted by dragondo1976
me and my friend fix the problem is very simple. if your cd changer is burnt i can fix it is very simple if anyone need help let me know and i will show you how i save atleast $600 hahaha
I
I'm going through the same thing right now I don't know if it's the CD changer but I have no sound I checked all the fuses and it's not that I don't know if it's the end but please let me know what you did might work for me
Old May 25, 2024 | 07:48 AM
  #50
Archtop56's Avatar
CLK320 Convertible, Land Rover Discovery 2
add me to the list lol
