NEED OFFSET ADVICE ASAP PLEASE!!!
Old Jul 15, 2009 | 11:40 PM
thunderbenz's Avatar
2015 SL400 R231
I did all the research but couldn't find anything solid.
I have w209 CLK dropped with H&R Sports.
Bought rims 19x8.5 F 19x9.5 R w/ 235/35/19 F and 265/30/19 R.
OFFSET is 32ET F / 35ET R.
I am not too concerned about the R, but will the FRONTS OFFSET fit my car/setup without sticking out too much?
Thanks!
Old Jul 15, 2009 | 11:44 PM
kiamcoj's Avatar
2012 CLS63
Thanks!
You should be golden!
Old Jul 17, 2009 | 03:10 PM
2015 SL400 R231
Thanks for your advise...
Thanks.
Old Jul 17, 2009 | 03:46 PM
Rashman's Avatar
Mercedes-Benz CLK63 AMG Coupe
I have 19" x 8.5 on the front with a 235 width tyre.
I have an offset of 35 and they sit nicely.
You have a smaller offset, so they will stick out more.
I have posted some pics of my car on the Picture thread. Maybe some of those will help you judge.
Old Jul 17, 2009 | 06:49 PM
2015 SL400 R231
Thanks!
Yeah its over with...done deal. Hope it dont rub.
Old Jul 17, 2009 | 07:17 PM
Rashman's Avatar
Haha. .
Just avoid hard cornering under heavy braking and you'll be good.
Old Jul 23, 2009 | 10:42 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
i'm running the same size and its still not good enough for me. i have no fitment issues at all though.
i want something that fits better. its still not flush enough.
Old Jul 23, 2009 | 11:08 AM
dariusf's Avatar
2023 CLA 250, 2021 GLC43, 2003 CLK320
Hi, just curious what brand of wheels and tires did you guys get? Where you got them and what was the total cost? I'm still researching the options.
Also any pics of the new wheels?
Thanks!
Old Jul 23, 2009 | 11:22 AM
reserved's Avatar
clk 500 (wifey's); 350Z roadster (daily driver); 350Z coupe (track car)
A difference of 3mm will not even be perceptible.
Also, to the OP, if you are concerned that you may have a rubbing issue, then make sure you choose the tire brand carefully. Toyo T1R would probably be a good choice as they have a more "rounded" shoulder than some other tires.
Your set up will almost certainly work just fine though
Old Jul 23, 2009 | 04:21 PM
AMGOODNESS's Avatar
03 CLK 55 AMG, IMCO muffler/Magnaflow tips, KW V1 coilovers, 19" Petrol Metrix Wheels
stretch a 225 up front and you will be fine. stock offset up front is 37mm. so you will push 5mm out closer to the front fender. i run coilovers so i had to run 8" wheels up front with 20mm offset. all my wheels sit flush. i am slammed on coilovers with only a one finger fender gap.
i run 9.5" rims in the back as well and they look better in my opinion with 255's. gives it a slightly stretched look. plus it helps minimize any rubbing.
Old Jul 23, 2009 | 08:06 PM
2015 SL400 R231
Thanks to all...................
Old Oct 25, 2009 | 02:42 PM
icecream's Avatar
W211 E55 - W209 CLK (gone)
hi, anyone here know if rims from slk r171 or e-class w211 will fits w209?
