Blinker Lamp
edit: you can purchase just the blinker from the dealership for like $37.
Not easy at all. Have to remove the mirror glass and the inner cover first. Good that I did not attempt to do it myself.
Once the turn signal is out, you will need to remove that stainless steel part as it provides a friction fit into the mirror housing. It is a PITA to remove as there is a small stainless tab that needs to be pushed in while lifting the part off the signal. You will then need to install it on the new part. If you have stainless picks or dental instruments, it makes the manipulation of the pin/spring much easier into the mirror so it locks in place.
