noob coilover question
Old Oct 6, 2009 | 05:29 PM
bheng's Avatar
2003 CLK 320
hey guys. i was wondering about some suspension set up some of our guys have.
I mean i just did a quick google search. and there are a couple brands out there now. I mean. there are D2 racing for 1k and K Sport for 1k. both offer just about the same. KW v1 is 1.6k and v2 for 2k. so whats the difference? are these cheaper set ups worth it? or would it be better to either spend more cash on the v2 OR get a good spring and shock/strut set up?
B Heng.
Old Oct 6, 2009 | 05:40 PM
FastDonzi's Avatar
'10 c63,'03expedition,ducati999,22'Donzi
if you go for coil-overs, go with either KW or bilstein.i have H&R springs and Koni adjustable shocks which work very good as well.
Old Oct 7, 2009 | 12:01 PM
astropat's Avatar
CLK 320
You also have to consider how low you want to go.
Old Oct 7, 2009 | 03:22 PM
bheng's Avatar
2003 CLK 320
i dont know how low i want to drop it. probably only in about a an inch or so. im from the sf area so i dont want to scrape up driveways or down hills much.
i guess i should be leaning towards springs and shocks. cuz i dont know how to set damper setting and such.
also i dont want such a harsh ride because some of the sf roads are rough and have a couple of pot holes here and there.
yo astropat, how does the ride on coils feel? too hard compared to springs?
Old Oct 8, 2009 | 01:13 PM
astropat's Avatar
CLK 320
It's more stiff, but it isn't uncomfortable. Mine is dropped almost 2 in.
I bought my coilovers used. The only bad part of it was that coilovers are usually adjustable with these collars they have on them, so you can adjust the ride height pretty easily. So I can't raise it if I wanted to without switching them out completely.
I can see how driving around in the bay may get sketchy. IMO, I think buying a new set of coilovers is worth it (or a used set that works properly). The ability to adjust your ride height is priceless. You can make the ride height at exactly what you want it to be. When you switch you wheels or whatever, if you don't like it, you can go higher.
I don't think the ride on coilovers is hard at all. My buddy has his 350Z all fixed on coilovers too. I think my H&Rs on the lowest setting still feel 100x more comfortable than his. My ride doesn't feel all floaty like it did stock. You feel like your car is more grounded and can maneuver better. Of course you'll watch out for potholes and drive carefully anyway. It's not that bad.
Old Oct 8, 2009 | 10:28 PM
PH1L's Avatar
CLK w209 GLC43 coupe
im using KW v1 well its alright for me tho...the kw v2 u can adjust the damper setting.... so if u not gonna go to track i think the V1 will be better
Old Oct 9, 2009 | 11:46 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
why do you say, V1 is better than V2 ?
isn't damper great to adjust? (the rebound time)...
Old Oct 9, 2009 | 01:38 PM
PH1L's Avatar
v2 is better.. than the v1...
if u not gonna adjust the damper setting much i recon v1 is... plus its cheaper...
suspension shop told me that the v1 is already enough for me unless i wanna take the car to track he would recommended me the v2
