List of Repairs! Bad Economy! but I'm handy
Old Dec 9, 2009 | 02:00 PM
bradfordjboyle's Avatar
2004 clk55 amg
First off I'd like to start out by saying thank you for everyone's help with the Crank Position Sensor.
Mercedes-Benz of San Diego wanted $525 to do it. I was able to buy the part, and since I didn't have a female torque wrench, I tipped the local body shop to do it for me for $60 and a 30-pack.
Well worth it in my book.
In any case, I now have a list of repairs that I need to have done because they either want more money, or the bushings are truly cracked and leaking.
Below is the list of repairs and how much they want. I started thinking that I could most likely do the Fuel Filter and the Air Filter myself.
At least I'd save a few bucks, Any other suggestions or links to these repairs would be most appreciated. Thanks everyone.
1. REC. SPARK PLUGS $375.00
2. REC. FUEL FILTER $675.00
3. REC. AIR FILTER $125.00
4. REC. BRAKE FLUID REPLACMENT $120.00
5. REC. FRONT BRAKE PADS AND ROTORS. $683.00
6. REC. TRUST ARM BUSHINGS $550.00
7. REC. VALVE COVER GASKETS $732.00
Old Dec 11, 2009 | 09:43 PM
ceeclass's Avatar
06 C230 Sport 06 CLK350
Use the search function in this forum to find all the DIY articles. I just bled the brakes on our 06 C230 (Same process as a CLK). The brake fluid was $20.00 from the dealership and the Motiv Brake bleeder was about $50 -$60 from Amazon. Took about an hour. Easy job. While you're at it, just replace the pads and rotors. should be around $250 - $350.00 for parts. Should take a couple of hours to do this. Air Filters, same thing. Go to AutohausAZ (About $35.00) or order K&N filters ($75 - 90.00) and do this yourself. Easy to do. Most of the general maintenance on these cars is easy to do. Good luck.
Old Dec 12, 2009 | 12:33 AM
Flame3g's Avatar
CLK500 SPORT
hey i just got a new airbox with brand new filters in it...you can have them for $30...shipping included
Old Dec 18, 2009 | 09:42 PM
dariusf's Avatar
2023 CLA 250, 2021 GLC43, 2003 CLK320
Do it yourself or find a Mercedes dealer mechanic that does stuff on the side. You should save up to 50%
Old Dec 19, 2009 | 10:17 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
I did the spark plugs, valve cover gaskets, and crank position sensor myself and only spent like around $200
