Connect Ipod or Sat Radio in USA?
Old 02-05-2010 | 12:03 AM
JHouse's Avatar
2014 CLS 550 & 2004 CL55
Question Connect Ipod or Sat Radio in USA?
Anyone know the best/cleanest way to connect either an Ipod or Sirius or XM radio to a 2004 CLK 320?
Old 02-05-2010 | 10:07 AM
JHouse's Avatar
I read the manual last night and it appears I can get a Sirius satellite tuner that is built for the radio from MB dealers like I did for a Navigator.
Still don't know about the Ipod thing though.
Old 02-05-2010 | 03:36 PM
guofan's Avatar
W209 500
see if you have Aux.
Old 02-05-2010 | 04:04 PM
M-bENZ's Avatar
Corrolla
I dont think he has it if his car is stock.
Andy
Old 02-07-2010 | 02:42 AM
JHouse's Avatar
Going around in circles. As to Ipod, just went to a site recommended on another forum and found two compatible interfaces. One for $450 and one over $650. http://www.icarkits.com/advanced_search.php
Now trying to find the SAT gizmo. The radio does have a SAT button and the manual says it will interface with a satellite radio, but it is extremely vague. I guess I will ask the dealer and they will want $1200 or $1400 plus for it as usual.
Old 02-08-2010 | 01:52 PM
lkfoster's Avatar
'19 AMG E53 Cpe, '23 EQS 580 SUV, '88 560SL, '35 Ford 5w coupe, '53 MGTD and others
When I ordered an iPod adapter kit for the wife's Audi from DICE the webpage said MB also. You might do a search for DICE iPod Mercedes. The Audi kit plugs into the back of the radio between the HU and the CD changer. Cost was $110 on Amazon.
Old 02-08-2010 | 01:56 PM
JHouse's Avatar
Wow, that's a lot cheaper. Thanks for the tip.
Old 02-08-2010 | 02:09 PM
lkfoster's Avatar
Apparently it's a bit more complicated for you car from what I briefly found.
http://www.amazon.com/i-Mercedes-D2B...4&sr=8-1-spell
The OEM factory kit that I bought for my '06 w203 was a lot less.
Old 02-08-2010 | 02:13 PM
JHouse's Avatar
I was just figuring that out. It looks like there are two entirely different applications from the same company. One is a high quality FM transmitter that will also plug into the antenna input on the back of the radio. It is the $130 unit. Then there is the expensive one that replaces the CD changer and allows you to operate the IPOD (hidden in the glove box) with all the CD controls on the dash and on the steering wheel. Sounds good.
Old 02-08-2010 | 02:18 PM
lkfoster's Avatar
The wife's Audi is using a Sirius adapter into the FM antenna lead and I can't say that the sound is bad. I plan to switch it to the direct feed iPod adapter when I get back to the states, but we've lived with the FM method for the past two years without any complaints.
I should also add that the sound is better than my OEM iPod adapter on the w203.
Old 05-04-2011 | 02:26 AM
JHouse's Avatar
Well, I got frustrated and went cheap and it worked out pretty great. I got one of those $15 cassette adapters and stuffed all extra wire (guess I should just splice it and get rid of all the extra wire) on top of the cassette and left about three inches coming out the side of the door and pulled it down between two buttons. So I just plug the iPod in and stick it in the open slot where I keep my phone. Looks clean and sounds perfect. Just select Cassette and listen. Also allows me to plug it into my Droid2 and listen to Pandora Radio (the coolest thing in the whole world) and run the navigation application at the same time. If you set the volume output on the navigation program to medium and adjust the music where you like it with the car's volume, the music softens for each turn-by-turn instruction and then comes back up. It's pretty neat hearing the navigation come through the stereo.
Old 05-05-2011 | 11:08 AM
JHouse's Avatar
And here's how it looks. Not too chicken****.
Old 05-05-2011 | 11:21 AM
ark1tech's Avatar
2003 CLK 500
I have the exact same setup as you Jhouse.. It is much simpler and the sound is perfect!
Old 05-05-2011 | 11:27 AM
JHouse's Avatar
Ark1tech- Those are the wheels I'm looking for. Tell me everything!
Old 05-05-2011 | 11:40 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
+1
Old 05-05-2011 | 11:55 AM
ark1tech's Avatar
2003 CLK 500
Jhouse what are you talking about?
Old 05-05-2011 | 11:58 AM
JHouse's Avatar
The wheels on the car in your signature. Those are exactly what I'm looking for. Can you help?What's the tire/wheel combo dimensions and the type and source of wheel? I've been banging my head against the wall on this.
Old 05-05-2011 | 12:18 PM
ark1tech's Avatar
2003 CLK 500
They are just the stock wheels that came on the car.. They are 17" all around but they are staggered. Front is 17" x 7.5" and the rear is 17" x 8.5".. Tires sizes are - 225/45-17 (Front) and 245/40-17 (Rear)..
Old 05-05-2011 | 01:49 PM
JHouse's Avatar
I'll be damned.
Old 05-05-2011 | 01:56 PM
ark1tech's Avatar
2003 CLK 500
haha yeah.. I haven't change my sig in a while, but they are black now..
Quick Reply: Connect Ipod or Sat Radio in USA?
