car lightly shaking in idle?
I dont know if this is recent. I usually have my music up and my sub hitting. but i put it on mute for some reason and i noticed my sweater was in a constant vibrating motion. and then i realized that the whole car felt like that.
I have a CLK 320 at 72k mi. just wondering if its normal cuz my car is getting old. or is it foretelling that something is going to go out soon?
any of you guys had this experience?
Clean your MAF with MAF cleaner.
If not, check to see if you have any codes stored.
If nothing there, check your motor mounts.
Mercedes motor mount are easy to replaced. I used the hydraulic jack to push up the engine to removed and installed the motor mount. Don't re[lace it if there's no sign pf fluids leak. If no leak, you might want to tight the bolts down tighter.
im not great but i can do the basics and have the skills to figure stuff out. so i guess after what my friend says, i'll do research on it and see what my options are. thanks for all the replies. hopefully i can get it checked out soon.
Klinh is correct, the motor mounts can be tightened down if there is no fluid leak. If all the fluid has leaked out, then you should replace them.
As a part, they are not expensive. Something like $150 each. At the dealer, it's the Labor that will drive the costs.
thank god extended warranty covered it.
