door lock question....
There are 2 settings to the locking system.
1) you can set the key fob to open just the drivers door and petrol cap when you press the unlock button.
2) you can also set the key fob to unlock the entire car (doors, boot & petrol cap).
To change between the 2 settings, you need to press and hold both the "lock" button and "unlock" buttons for about 6 seconds.
It will cycle between the 2 settings each time you press and hold the buttons.
Consult your manual just to make sure that's how you do it.
I have mine set to "solo" mode, as I call it, and it's been a while since I set it.
When you have it set to Solo mode, press the unlock button once and it will open the drivers door and petrol cap. Press it again and it will unlock the rest of the car.
C-Class may well be different to CLK Class.
Also, when you pull away, the doors will automatically lock when you reach 5mph.
This is a safety feature to prevent someone opening your door and pinching your wallet/ phone etc when you are sitting at lights, for example.
There is also a lock/unlock button up on the dash by the hazard/ warning light button. You can use this to lock/unlock the doors at anytime.
Andy
Just the drivers door will unlock and open when you get out.
If you had a passenger, then they would be able to open the door and get out just like you.
The passenger door would then stay unlocked.
