Transmission question...
Old Mar 12, 2010 | 10:03 PM
idouoooo's Avatar
2005 CLK500 Cabriolet 2004 Maserati GT Coupe 2004 BMW 328cic
Hey guys im n00b to the site so go easy on me...
Any help with my problem will be appreciated!!
I had to replace the engine and transmission on my 2006 CLK500 and after doing so the transmission wont change gears. The car starts up and engine is running fine but it wont shift out of parking. The engine and trans came out of a 2005 CLK500 (which i was told by Mercedes are the same) and fit right in with no problems. I had no problem starting the car but the shifter wont get out of parking.
Any ideas?? I wanted to try the forum before i tow the car to the stealer as i know this is a great resource.
Old Mar 13, 2010 | 11:19 AM
idouoooo's Avatar
maybe one of the mods should move this post to the tech area????
Old Mar 13, 2010 | 11:41 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Give it a little more time someone should be able to help. Sounds like something is wrong with the tranny but don't quote me
Old Mar 13, 2010 | 03:00 PM
directordat's Avatar
CLK 500
one time i had a fuse missing and that was the problem for me.
Old Mar 13, 2010 | 03:14 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Good to Know! I never knew a fuse could cause that
Old Mar 13, 2010 | 08:48 PM
idouoooo's Avatar
anyone know if the shifter needs to be programmed or something ??
Old Mar 13, 2010 | 08:54 PM
M-bENZ's Avatar
Corrolla
Did you use the ECU/TCU from your 06 clk500 ?
Andy
Old Mar 13, 2010 | 09:19 PM
idouoooo's Avatar
yes im using the ECU from my 06 but i do have the ECU, Immobilizer and key from the 05 car that the engine and trans came from. where is the transmission control unit? is it inside the trans? do i need to change that as well?
Old Mar 13, 2010 | 09:54 PM
M-bENZ's Avatar
Corrolla
that I dont know hopefully someone can chime in and tell you.
Andy
Old Mar 13, 2010 | 11:06 PM
BENZADI's Avatar
W209 CLK And 2007 GSX-R
Most Of The W209's Have The 5spd Tranny ....So idk see why not...
Old Mar 14, 2010 | 04:18 AM
supacrazykev's Avatar
GLE 450 2021, SLK 350 2013, Honda Civc Type R 2019, Suzuki GSXR 750 2014, Ducati Diavel 2018
I thought most of the W209s have 7 spd Tranny. I have a 7 spd tranny
Old Mar 14, 2010 | 08:41 AM
WPOZZZ's Avatar
W211 E55, 911 turbo, 911sc, RX330
Does it feel as if something is blocking the shifter? I believe most auto cars have shift interlock that blocks the shifter from moving out of Park unless your foot is on the brake. There may be something wrong with one of your switches/sensors.
Old Mar 14, 2010 | 12:18 PM
idouoooo's Avatar
well its not moving at all, its like trying to shift without having your foot on the brake pedal. i did not have this problem prior to the engine/trans swap. on another tech forum someone told me i may need to have the dealer "program the shifter" ...anyone know anything about this?
Old Mar 14, 2010 | 03:30 PM
CLK 500
luckily i figured it had to be something with the fusebox because the dealer was about to charge me around $1000 for a new shifter/gear box or something
but still just for a fuse..they charged me around 200 bucks
