alpine audio system
Old Mar 24, 2003 | 05:25 AM
mjh731's Avatar
2003 CLK 500
alpine audio system
here are some pics of the alpine system i had installed (a special thanks to Matt M--the audio expert)
-Alpine CDA-7998
-Rockford Amplifier
-Rockford 12" Subs mounted on rear decklid
Old Mar 24, 2003 | 05:27 AM
mjh731's Avatar
2003 CLK 500
here's the CDA-7998 open
mjh731's Avatar
2003 CLK 500
mounting of subs on rear deck lid
Old Mar 26, 2003 | 10:28 AM
W0n6_3d4n's Avatar
C200K (w204)
Sweet setup!!! How's the bass sounded like with that type of configuration?? It's free air right?? I was thinking of putting free air on my C but then it may not be loud enough for me
Old Mar 26, 2003 | 08:46 PM
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
Did you use MDF board between the subs and the read deck??...looks like it to me ...
Old Mar 26, 2003 | 11:56 PM
mjh731's Avatar
2003 CLK 500
with respect to the free air, this configuration is excellent. it's as if it uses the entire trunk as the box...i have it on bass level 8 (180 degrees) and it hits pretty hard.
yes, that type of board was used. then we covered it with grey carpet.
one thing I found out was that there are no "rear"speakers...only the one's in the driver and pass. door. I plan to upgrade the speakers on both doors.
Old Mar 27, 2003 | 12:02 AM
bajaiman's Avatar
Where did you install the amp?? … how heavy are the subs?? … currently I’m also using MDF board underneath the rear deck but I’ve got 2 amps on it instead of the subs.….I was just wondering if the board can handle the weight of the subs
Old Mar 27, 2003 | 10:58 AM
rgiorgio's Avatar
CLK, ML, GL
Were you able to integrate the steering wheel controls and the display in the speedometer?
Old Mar 27, 2003 | 12:09 PM
mjh731's Avatar
2003 CLK 500
the amp is installed in the left front portion of the trunk up against the wall. i would venture to guess that the board could hold the weight of the subs as my configuration has no problem doing so.
the steering wheel controls and speedo display do not work with aftermarket equipment. in addition, the S.O.S. feature is disabled. However, I have AAA so the loss isn't much of an issue.
