Is there a way to reset/normalize power window?
Old Jul 27, 2010 | 03:26 PM
jawsplace's Avatar
1992 400SE, 1997 S500 Coupe, 2019 C300 4MATIC
My rear driver's side window pops down like it should when the door is opened but it does pop back up to seal when the door is closed. All the other windows operate fine and seal properly. How can I fix this?
Old Jul 27, 2010 | 03:50 PM
Clkboi's Avatar
CLS550 4Matic
i had this issue before.
Somebody advised me here to remove my battery for 15 min and than put it back on.
Alarm should go off when you connect it and your windows and sunroof will be all messed up.
You need to drive the car for at least 3 miles and it all goes back to normal.
Good luck
Old Jul 27, 2010 | 04:21 PM
jawsplace's Avatar
Good luck
Thanks. I'll give that a try.
Old Jul 31, 2010 | 06:08 PM
qais.samawi's Avatar
Mercedes Benz CLK 200 Kompressor - 2005
try to push down the button of driver window till the window is down completely, keep pressing the button down for around 10 sec, after that pull up the button till the window is up completely, and keep pulling the button for around 10 sec.. do the same for the rear window, this should calibrate the mechanism correctly
