sevas s-22 fitment
2004 clk320
sevas s-22 fitment
whats up fellow members! Im a newbie here. Well first off i found a good deal
for 20x8.5 20x10 sevas s22 wheels but theyre used. I plan on purchasing 225/35/20 and 255/35/20. Are H&R spacers good to install as well so they are hub centric? Please give out your opinions on my idea whether its good or bad.
H&R spacers are good but what you really need before buying spacers is to know the exact offest and face style to make sure it fits and clears the calipers.
2004 clk320
The rear wheels rub against my wheel well lining, so i took the lining off. There is no offset engraved in the back of the rear wheels, but the front offset is 40 and unfortunately it slightly rubs against the strut. I plan on running 10 mm all the way around and not lowering the car at all. The wheels clear all calipers well and Im happy with my purchase..updates with pics in a few days
2004 clk320
yah ill have to agree with you on that. I just got spacers and the center bore fits snug on my hub but the outer bore is a tad bit smaller than the bore on my wheels. Isnt it suppose to fit snug too?
19 C300
there is no way you will get those wheels to balance with a 10mm spacer.
The wheel will not be touching the hub of the car (our cars have small hub flanges) If you need that much modification the wheels just don't fit. Save yourself a bunch of hassle and go with something else. I hate to be the bearer of bad news, but those wheels were not designed to work with your car.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
2004 clk320
My spacers fit snug on my clk hub bore, but my wheels's bore is too big for the spacers so i got hub centric rings to put on my spacer's outer bore to fit snug on my wheel.
19 C300
like i said... the wheels don't fit.... but if you insist on making it work... good luck to you, they look like nice wheels,
2004 clk320
I'll need some luck to make it fit flush. It's my first time doing this spacers and hub rings and making it fit but its all part of the hobby. I was even surprised when i took off the lug bolts because im used to lugnuts as my previous car was an eclipse. My tires should be in soon. Pics to come when my tires arrive
2004 clk320
Greaaat! I cant get the fronts to balance but the rears are perfect with
the 12 mm spacer and hubcentric ring. No shakes or vibrations. Can anyone suggest
a solution for the fronts? Its that tapering hub i cant
put a hubcentric spacer in the fronts. If not then too bad and its already posted on CL
in Las Vegas.
in Las Vegas.
